replacing console
Old Oct 22, 2002 | 01:29 AM
phantomcamaro's Avatar
replacing console
hello...
im gonna replace the center console out of my 91 rs with one from a 93. the problem is, ive yet to figure out how to remove the old console. i cant really find any screws other than whats on top..
this is really baffling to me. help!
Old Oct 22, 2002 | 06:14 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Assuming a 91 is the same as a 86, it comes out in 2 pieces. To remove the top part, remove the bolts in the storage bin, 4 I think. Remove e-brake handle and shift ****. Remove shifter/ashtray plate. Remove trim around radio and hvac controls. Remove radio and hvac controls. Remove 4(?) bolts holding upper console to lower console. Unplug power window/hatch switches. Remove upper console. In the biddle of the lower console there is a metal brace with a bolt running horizontal. Remove that bolt. Remove lower console.
I may have forgotten a bolt or 2, but here's a starting point.
Old Oct 22, 2002 | 10:01 AM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
the lower console also has a bolt on each side that bolts up under the dash
Old Oct 22, 2002 | 07:17 PM
thanks..that helps alot. once i get into doing it, should flow easily.
i was baffled cause i couldnt even find where to begin.
1992 Trans Am
May 10, 2023 07:19 PM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
Casey Meyers
Mar 2, 2016 10:46 AM
Winchester1094
Interior Parts Wanted
Aug 19, 2015 05:01 PM
TheJoeY88
Aug 13, 2015 06:51 PM
