Why Sloppy Fitting Windows
Old Oct 28, 2002 | 06:40 PM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
Both the windows in the doors of my '86 Firebird are a sloppy fit and rattle, leak, and make noise at highway speeds.
It is getting too cold for working on the car now, but what is the most likely worn component that makes the windows so loose?
I can roll the windows down a couple of inches from completely closed and easily move them an inch in or out.
Before I tear the door panels off (hopefully in the spring) to investigate I'd like to hear some feedback on what is likely the culprit.
Old Oct 29, 2002 | 07:20 PM
AT4 T/A at work's Avatar
I've got the same problem. In my case, it's the felt runners in the inside of the door that have worn away exposing the metal beneath. It's also the ancient cracked, warped, and missing weatherstrip, and the slightly loose bolts on the door interior. I think you and I are in the same boat. We both need to take apart our doors and replace/tighten what we have.
Old Oct 29, 2002 | 08:27 PM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Same boat alright.
For a second I thought you had seen my car.
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
dbrochard
Aug 30, 2015 05:56 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
