Tail Light Fix
Old Nov 1, 2002 | 04:59 PM
AT4 T/A's Avatar
Car: 1989 IROC-Z
Engine: L98 350
Transmission: New 700r4 Done by 11/14/07!
Tail Light Fix
Hi guys. Has anyone ever taken apart their tail lights? Look in my picture below and you'll see why I want to do this. The "grid" pattern is coming away from the outer shell and looks like crap. Since I am replacing my '84 lights with some '86 grid style, I want them to look good! I think I should be able to pop the two clips on the bottom and pull the light apart. Should I be able to use any old gasket maker to seal them back up? What kind of adhesive should I use to put the "grid" pattern back against the outer shell? Should I just use model glue? What do you all think? Anyone got a center section for sale while I'm at it?
Old Nov 3, 2002 | 12:43 AM
sheltonw3's Avatar
Car: 91' TRANS AM Modified
Engine: Classified
Transmission: Auto with Overdrive
TAIL LIGHTS
Been there tried that and its not as easy to pull that grid part out so it might be better to find the 91-92 tint style t/a if you can, and that style tail light you got is actually the 85' bubble style which I believe was used from 85' to 89' only that I can recall.
But if it works good luck!
Frozer!!!
Jan 19, 2024 04:55 PM
Jk_Under
Sep 2, 2015 10:59 PM
LittleFranks
Aug 20, 2015 03:55 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Omega
Aug 10, 2015 12:46 PM
