Wiring up inflatable lumbar support on 4th gen seats
Old Nov 2, 2002 | 07:50 PM
Nasty_Bird_'90's Avatar
I just got a set of '95 T/A seats that have the little airbags in the side bolsters. I was wondering if anyone has hooked them up in their 3rd gen?? If so, how? TIA
Old Nov 2, 2002 | 08:41 PM
Steve86TA's Avatar
Car: To many to list
Hey man,did you get the air tube that goes from seat to seat?If not you can prolly run a piece of vaccum hose.I think mine were only a hot wire and a ground.Pull the carpet up,you may have a plug already there.I did.
Old Nov 2, 2002 | 11:39 PM
2vmodular's Avatar
from a 00' bird
Old Nov 3, 2002 | 12:05 AM
cg91ta's Avatar
Car: 1991 T/A - Sold (sniff) 1980 T/A Pa
If you didn't get the hose and wires combination that run between the seat, you have a lot of work to do. It would be worth the time it takes to run to a junkyard and get one. Once you have that, you'll only need a + wire from a large amp circuit under the dash (power windows worked for me as they already had a breaker installed). Under the center console is a place to run a groud wire to complete the circuit.
GL!
Old Nov 3, 2002 | 09:00 AM
I hooked up a hot wire and a ground before I installed them and got the little pump to work. I dont have the hose that goes from seat to seat. All I have on each seat is a plug and a small air tube with some kind of white clip at the end. What do I do with this? Thx.
Old Nov 3, 2002 | 05:55 PM
cg91ta's Avatar
There is a combination air hose and electrical wiring connector that goes between the seats. You NEED this. Contact the person you got the seats from or a junk yard.
Old Nov 3, 2002 | 06:50 PM
Ok, cool. I'll call the salvage yards. Just wonderin', what exactly are they for?
Old Nov 4, 2002 | 07:06 PM
cg91ta's Avatar
The switches on the seats only redirect the energy to the pump motors and seat motors. It all works of a single + wire. The air tubes that run between the seats have to positively seal or your lumbar and bolsters wont work. I tried to make my own, but the harness makes it 100% fool proof.
Old Nov 4, 2002 | 08:36 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Any year GTA will also have these seats and the same wiring harness and vacuum lines.
Old Nov 5, 2002 | 08:21 PM
Greg99LS1's Avatar
Car: 2012 Corvette Grand Sport 'vert
Engine: LS3
Transmission: 6L80
Axle/Gears: 2:73
GM P/N for seat harness
From my post at LS1.com:
I had to order the harness that connects between the seats to provide power and air for the passenger side, GM P/N 12177553, from GMPartsDirect.com:
SUB TOTAL: $53.53
SHIPPING: $10.71
TAX: $0.00
TOTAL WITH TAXES: $64.24
These are for the 98-up AQ9 seats.....I can't confirm whether it will work with '93-'97 seats.
Old Nov 7, 2002 | 06:08 PM
Thanx for the help man. BTW, you outta bring that LS1 up here to MD so I can make it fast! J/k. You know a guy named Jeff Beeler ?
Old Nov 7, 2002 | 06:59 PM
johnyIROC's Avatar
I made my own hose/wiring harness... it was easy and worked great. Save yourself $50.
Old Nov 7, 2002 | 09:14 PM
paul russell's Avatar
Car: 86 trans am
Engine: 5.0 tpi gtauto ramair and notch
Transmission: 700 r4
hey greg could you post the part mumber again i called gm and they said its missing a # also went to the site you listed...thanks
Old Nov 7, 2002 | 09:34 PM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
I have the inflatable bolster supports in my seats as well. I also grafted a 6 way power thirdgen track onto the power lubar seat, if you are looking to do that as well. I did not get the hoses and harness with mine either, I made my own. The seats really only need the hot power feed, all the rest is pretty easy. As far as the vac tube, this sounds nuts, but I used $0.99 for 6 feet at walmart aquarium pump tubing. Perfect fit, easy to work with, and has worked for years with no problem. Let me know if you have any other Q's.
Old Nov 8, 2002 | 07:59 AM
cg91ta's Avatar
I got mine from the guy I bought the seats from for free. I just had to ask. I've also heard that a couple local boneyards quoted 8-10$ for that part.
Old Nov 8, 2002 | 08:12 AM
Greg99LS1's Avatar
Engine: LS3
Transmission: 6L80
Axle/Gears: 2:73
Fixed it above.....missing a "5".
Old Nov 8, 2002 | 02:55 PM
Greg99LS1's Avatar
Engine: LS3
Transmission: 6L80
Axle/Gears: 2:73
No, I'm afraid I don't know Jeff...
Fast? Which LS1? Actually, I feel like the Z28 is fast enough for now....I won't do any engine mods until I have to overhaul the thing....then I'd probably do the LS6 intake, heads, cam and headers route and see if I could get 400 RWHP out of it on the dyno...with that stuff, it should be pretty easy.
If I do any mods in the near future, it would be with the suspension....I feel that this '99 is the exact opposite of what my '83 was....great power and average handling.
That '83 handled FAR better than the stock calibration GM put in the LS1 cars. I think they set the cars up to understeer intentionally to make them more forgiving of too much throttle....
I wish I could combine the best things of my current '99 with that '83.....like transplant the drivetrain, brakes, interior of the '99 into the brand new chassis of the '83 and have my AQ9 seats re-upholstered to match the rest of the Lear/Siegler Conteur interior in burnt orange/charcoal grey....now that would ROCK!
Old Nov 8, 2002 | 03:49 PM
ES87iroc's Avatar
Engine: 5.7L TPI
Axle/Gears: 3.42:1
:sillylol: :lala:
Old Nov 30, 2008 | 10:40 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: GM P/N for seat harness
just in case anyone looks at this again for reference - they are now 165.00 from the dealer and 115 from a jobber. they thell me that have been discontinued and as of this date the only place the dealers get them from is a warehouse in tenn - so be prepared to wait a while for it - about one week.
the current part number is 12177553
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Casey Meyers
Mar 2, 2016 10:46 AM
AkDrifted
Aug 17, 2015 07:45 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
