Retrofit Ground Effects
Old Nov 8, 2002 | 09:29 PM
Berlinetta's Avatar
Can i do it? Besides the ground effects themselves, what the hell do i need to get it done?
Old Nov 9, 2002 | 12:49 AM
un4givin89's Avatar
if you mean putting gfx on your Berlinetta all you need are the gfx and a drill and some bolts its easy!
Old Nov 9, 2002 | 12:54 AM
Berlinetta's Avatar
aren't the ground effects mounted to brackets?
Old Nov 9, 2002 | 12:56 AM
un4givin89's Avatar
not really
just bolted to some holes undernead the bottom of the fenders were it rolls.
Old Nov 9, 2002 | 01:10 AM
Berlinetta's Avatar
i think i may need a new front clip. Ive heard the berlinetta has a different front clip and that it wont accept ground effects. not sure if this is true or not
Old Nov 9, 2002 | 10:47 AM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Yep, the front bumper is totally different. Also, there -ARE- brackets that the GFX mount to under the door. Look at the car that you take them off of and you will see what I am talking about, they are pretty big and hard to miss. You will need to either cut those off the car, or rig something up on your car. The brackets are welded to the body.
Old Nov 9, 2002 | 01:36 PM
NastyEssCee's Avatar
is that a 85-90 formula/trans am spoiler i see on your roc...hmm never noticed it....looks nice, id like to see what the aftermarket 4th gen style WS6 spoiler would look like on a roc
Old Nov 10, 2002 | 09:44 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Ah the ground effects conversion. I did that a while back to my 85 sc. Its real easy to do. When you take the gfx's off of the donor car, make cardboard templates that percisely locate the holes that you need to drill. EX for the door gfx,line the bottom corner of the door up with the bottom corner of the cardboard and poke the holes into it then line it up on your berlinetta and drill through the holes you put onto the cardboard and youll be set. As for the side gfx support that goes under the door, get some strong thin metal that doesnt eaisly bend and bend it to the V like shape it needs to be attached to the body and mate flat with the gfx. Then you need to weld it to the car and put the rocker panel gfx on and make sure its lined up correctly and drill the holes for the mount in their proper locations and your done with that part. I hope I sorta made sense
Old Nov 10, 2002 | 10:53 PM
Berlinetta's Avatar
thanks for the posts. I know a guy that teaches paint and body for a living so im kinda hoping he can help me.
Old Nov 10, 2002 | 11:03 PM
ES87iroc's Avatar
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Yep yep. It's a factory rubber one for now though, next summer it gets the boot for a fiberglass replacement. I see why the firebird guys hate the factory spoiler material.
Old Nov 11, 2002 | 01:39 PM
very sweet ive seen your posts but i never noticed that spoiler and when i was scanning through i was like HOLY CRAP THAT LOOKS SWEET...but dude seriously by the aftermarket 4th gen WS6 spoiler it looks badasshttp://www.gtautoacc.net/newwing.html
$750 L98
Feb 1, 2025 02:25 PM
Falcon50
Aug 22, 2020 03:26 PM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
lewandom
Oct 1, 2015 08:15 AM
Damon
Sep 26, 2015 04:29 PM
