Hood problems
Old Nov 16, 2002 | 09:05 PM
Hung Start67's Avatar
Hood problems
ok..92z...when cruisin down the road i can see the hood on the left hand side raising up,and the hood buffeting from the wind a touch. I adjusted the bumper stop but it still does this. If the hood supports are shot..which they are..will this cause the problem? or am i looking at something else..thanks.
Old Nov 16, 2002 | 10:52 PM
screaminformula's Avatar
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
sounds to me like the hood may be separating from the crossbracing, i would lift the hood and see if its not coming loose. other than that, i would check the hinges, are they still tight? if they have worked loose this would also cause a problem...i dunno, good luck though
Josh
Old Nov 17, 2002 | 03:57 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Check the rubber adjustment stoppers on either side of the header panel at the front. They may be out of adjustment causing the hood to lift and move around.
Old Nov 20, 2002 | 06:34 PM
Thanks fellas..will check it out this weekend.
Street Lethal
Apr 30, 2019 12:14 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Bert87
Aug 23, 2015 03:50 PM
bryan623
Aug 10, 2015 11:33 AM
3rdgenparts
Aug 6, 2015 09:03 AM
