door hinge
Old Nov 17, 2002 | 10:35 PM
DansZ87's Avatar
Car: 91 Z28
Transmission: 700 R4
door hinge
ok guys, big problem, im gettin my car repainted, and my doors were really saggin so i got a pin kit, that fixed them good but the drivers side is still saggin knows its the top pins that need attention how do i fix them, thanks
Old Nov 18, 2002 | 09:27 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
You replaced just the lower pins? The upper hinge repair kit by 3rdGenSolutions is what you'll need to repair it. That kit is available from 3 sources I'm aware of. 3rdGenSolutions, Top-Down Solutions and Spohn. The kit will fix the problem you are having.
Lon Salgren
Top-Down Solutions
Old Nov 18, 2002 | 11:04 PM
SilverTA's Avatar
pin kit
Thanks for the info Lon.
How much does the kit cost and how hard is it to install?
Old Nov 18, 2002 | 11:30 PM
lonsal's Avatar
For the price, check the web sites for each of the distributors or mfr. How hard depends on having the right tools on-hand or not. I purchased a special door-hanging jack from Harbor Freight. I recommend it over the cherry-picker method Andy recommends. You definitely NEED something to hold the door safely and securely while doing the job. I also made a couple of tools by modifying a 6" & 8" C-clamp to push out the lower hinge pin and the bottom of the two upper hinge pins. I prefer this method to trying drive them out with a punch. The top upper hinge pin can be pushed out using a long punch. You'll also need a Dremel tool to gind off the swaged ends of the old pins. I also highly recommend getting the spring removal tool that Andy and others have recomended (do a search on "door spring removal tool"). It is roughly a 3-hr job for me. It would be less if I didn't take off the inner door trim. But I need to only to remove one hidden screw holding the triangular door seal for better access to grind the hinge pins. I can e-mail you a sheet I created that details all the steps. Or you can follow the instructions on Andy's site. I also recommend replacing the door striker bolt while you are at it.
Lon
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Veaceonee
Sep 29, 2016 08:15 PM
86IROC112
Oct 9, 2015 10:38 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
codeysabatini
Sep 20, 2015 11:36 AM
