Do I need to prime plastic?
Old Nov 30, 2002 | 03:40 PM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
I plan on having the Formula painted come springtime, and I'm doing the prep-work myself during the winter. Do I need to sand and prime the plastic pieces (ie- the front facia/bumper/nose deal) or just have it painted over as-is?
Old Nov 30, 2002 | 05:21 PM
djunod's Avatar
Car: 1989 IROC
Engine: B2L/L98
It has to be primed with a plastic prep primer, and then again with your regular primer with a flex additive. You need to read the tech sheets for the paint system that you are going to use.
Here's a link that gives details for most popular paint systems:
http://www.autolign.com/pdfs/alpaintguide.pdf
BTW---Be careful sanding the plastic part, as you don't want to change the shape of plastic (along the lines of sanding paint off of fiberglass).
Old Dec 1, 2002 | 11:54 AM
DISTURBthePEACE's Avatar
Car: 89 Camaro RS
Engine: 2.8L V-6
No flex additive bad....
Use flex, flex is good...
Old Dec 1, 2002 | 12:03 PM
MdFormula350's Avatar
i would prime..
Old Dec 1, 2002 | 02:29 PM
djunod's Avatar
Car: 1989 IROC
Engine: B2L/L98
Is the paint that is on your existing plastic pieces fine? Not peeling off or cracked?
If it is perfect, then it just needs to be scuffed and sealed (with a flex additive). There is no good reason to sand down to plastic, as there is a good chance that you will change the shape of the plastic.
Old Dec 2, 2002 | 04:17 AM
FyreLance's Avatar
Haha, point taken
Old Dec 2, 2002 | 04:18 AM
FyreLance's Avatar
I don't believe there are any paint peels or cracks, I'll look closer though. It's 5:18 A.M. though and it's cold in the garage, so I'll do it later. I just can't sleep tonight....
gta892000
Aug 11, 2019 11:16 AM
RS Reaper
Oct 17, 2018 07:52 PM
MrPackstin
Oct 25, 2017 08:09 PM
Night rider327
Sep 25, 2015 04:19 AM
Saxondale
Sep 15, 2015 06:42 PM
