how to replace front TA hood vents?
Old Nov 30, 2002 | 10:58 PM
Diggler86's Avatar
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
Mine are faded so I got some to replace at boneyard, but the ones I got were just attached by some type of glue/foam stuff holding down the front part.
What do you use when you replace these to keep them in place? I also want to be able to take them off again!, so I dont want anything VERY permanent.
In my 86, Im not sure, but I think they have bolts?? The new ones I got the back slides under hood but the front has some adhesive on it.
Old Dec 3, 2002 | 05:10 PM
Diggler86's Avatar
Car: 86 TA
ttt
Old Dec 8, 2002 | 04:42 PM
Diggler86's Avatar
Car: 86 TA
neone?
i think its a 85-86 or 87-90 difference....
Old Jan 16, 2003 | 02:43 PM
Diggler86's Avatar
Car: 86 TA
ttt
Old Jan 16, 2003 | 02:52 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
nope....both my 87 and my old 92 had the bolts. I'm thinking that is one weird hood you got those louvers off of.
Old Jan 16, 2003 | 03:16 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
If I remember correctly, the speed nuts screw onto plastic tabs on the vent, when those tabs break, you have to use something else to keep them mounted, so the previous owner probably just glued them in.
I've got a hood with some vents in it that I don't need, make me an offer.
Here is the hood,
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
TheExaminer
Aug 25, 2015 07:34 PM
mizz0313
Aug 12, 2015 06:45 AM
