foil backed padding
Old Dec 2, 2002 | 11:16 AM
ROGER NICHOLSON's Avatar
foil backed padding
Just got started over the weekend, am going to put down foil backed padding under the carpet to help cut down on noise and heat especially comming from my headers. My question is should I just try to put this under the existing padding or pull the padding off the carpet then put the new down this would be a big job since it seams to be glued on the back of the carpet. Would it be to thick to leave the other padding on?
Old Dec 2, 2002 | 12:43 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
I'd say yank the old stuff and then put down the new padding. One reason for this is because that's just going to add more weight to your car. Pluss I think the new stuff will perform better thanthe old stuff. Just my $.02.
Old Dec 3, 2002 | 07:42 AM
97-1LE's Avatar
Car: 87 Trans Am
Engine: Built 350 Cam, Headers
Transmission: 5 speed
I used thedouble sided foil bubble padding as a heat barrier for my Corvette. I then put new padding and carpet over the foil padding.
Old Dec 3, 2002 | 08:15 AM
Double sided? where did you find that I dont think I have seen it
sounds like that would work even better.
Old Dec 3, 2002 | 08:47 AM
97-1LE's Avatar
Car: 87 Trans Am
The stuff I got is the double sided bubble foil, bought a roll of it
at Lowes . Its 4'X 20' X 1/4" thick. It only cost about $ 20.00. When I pulled out the old carpet from my car, I used it as a template to cut the foil. Laid it in the floor and then put my new carpet and pad over it. Most any Hardware store or lumber yard should have this stuff. I know a guy that has a 48 Ford and he insullated the entire roof and trunk area before putting in the headliner.
Old Dec 3, 2002 | 11:35 AM
Jza's Avatar
Jza
Originally intended to wrap your water heater tank with. Look in that aisle.
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Aug 13, 2015 08:28 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
Vintageracer
Aug 11, 2015 08:13 PM
