Does a 91 RS gage cluster work for an 89 RS??????????
Old Dec 11, 2002 | 08:18 PM
89 RS W/ T-56's Avatar
I have an 89 Camaro RS and I recently bought a 95 Trans Am's T-56 for it. The new 6 speed has an electric speedometer plug. My T-5 was a mechanical. 90 models and up Camaros are electric and plug into the 6 speed. I was wondering if I could swap my 89 cluster for a 91 RS cluster. Would it fit? and does it plug up to the stock harness? Thanks for the replies. Eric
Attached Thumbnails Does a 91 RS gage cluster work for an 89 RS??????????-scan0001.jpg
Old Dec 11, 2002 | 09:31 PM
CrazyHawaiian's Avatar
Car: too many ...
The speedo went VSS in 91. So no it wont bolt right up. It would require either a complete aftermarket solution, or extensive replacement of the 89 equipment to 91-92 specs. Then you would also need the conversion box to make the VSS signal from the T56 compatible with the 91 cluster (they have different pulses). You should contact Dakota Digital and see if they have a complete aftermarket solution. If they dont, you would have to upgrade the ECU to the 91-92 models and that means you would probably have to replace alot of other things I'm not aware of (i would guess the whole cluster backing plate that the cluster mounts into and maybe even the dash because the clusters have different sizes).
I'm getting ready to be in the same situation as you here pretty soon. I have a 90 (L03/700r4) with the cable speedo and I plan to swap in a T56 (and a L98). I've just decided to forget about the upgrade to 91-92 stuff and go straight to a 4th gen f-body dash.
Old Dec 11, 2002 | 09:55 PM
I appreiciate your reply. I guess that is a lot of trouble. Plus, later on I will be going LS1. I am sure I will have to go a differant direction now.
Old Dec 12, 2002 | 12:49 AM
loomdog32's Avatar
Car: 82 Camaro Z28
Engine: LU5 - Crossfire 305
Transmission: 200c - 3 Speed Automatic
u can swap clusters, but its a pain.. the 90-92 cluster is not a bolt in, u have to cut the dash and cluster to get it to fit and then bolt it down.. and the wiring harness is different.. do a search in the electronics forum for it.. i forget there names, but a few ppl have done it before.. if need be, ill dig thru my stuff and find the directions i used to do it..
-mike (loomdog)
Old Dec 12, 2002 | 09:19 AM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Yeah, do a search. This has been discussed before exactly. I just need info on swapping an Autometer guage in for my cable driven speedo! Any takers??
Old Dec 13, 2002 | 03:00 AM
loomdog32's Avatar
Car: 82 Camaro Z28
use a mechanical speedo?
to convert to a elecric speedo, there is a tech article on this site for that, tho its for a firebird (but it would work in ur case)
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
tnrednneck
Aug 13, 2015 08:57 AM
ChevyZ71
Aug 13, 2015 07:30 AM
Irocohio
Aug 12, 2015 08:03 AM
