rust sucks
Old Dec 12, 2002 | 09:54 AM
jc33's Avatar
Car: 1992 Camaro RS
Transmission: T5- manual five speed
rust sucks
is there any better ways to slow rust than grinding, primer and undercoating. my RS is starting the surface rust underneath. i hate rust it killed my bronco and 65 mustang. my pops owns a 80 camaro and the only reason it hasnt killed that is its never driven.
Old Dec 12, 2002 | 09:58 AM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Move to El Paso, rains here less that 15 times in a year.
Old Dec 12, 2002 | 01:35 PM
MILT's Avatar
Yes, grinding, coating w/ POR-15, priming, coating.
But once rust starts, it don't stop...
MILT
Old Dec 12, 2002 | 01:44 PM
MdFormula350's Avatar
por 15 will do a good job, run a search and find out how it works.
Old Dec 12, 2002 | 03:50 PM
jc33's Avatar
Car: 1992 Camaro RS
thanks for the tip ill check out that por 15 stuff.
Old Dec 13, 2002 | 06:18 AM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
get a grinder, a wire wheel, a welder, some por-15 and a 12 pack of (insert favorite beer here) just don't drink too much or you might miss and grind your window to shreads
Old Dec 13, 2002 | 07:29 AM
jc33's Avatar
Car: 1992 Camaro RS
yes i already figured the twelve pack to be the key to rust prevention. it helps to lessen the pain when you are grinding and realize you are looking at the interior carpet.
Old Dec 13, 2002 | 07:59 AM
Black88GTA's Avatar
Car: 88 GTA, 94 BMW 840, SVX, Prelude
Engine: 383 w/ Super Ram
Transmission: built 700R4 auto
WIRE CUP BRUSH!! One of these, attached to an angle grinder, is THE best tool to use to remove rust. The lil wires get inside the rust spot, pull out all the rust, and leave all of the good metal behind. Then you can just put in filler, sand, and paint.
Old Dec 13, 2002 | 08:51 AM
Ace_Murdock's Avatar
Car: 1985 Z-28
Engine: a big one
Transmission: 4 spd auto soon to be a 6 speed
yes the wire brush is very good at removing rust.
it is also good for removing built up road dust out of the wheel wells.
Pac J
May 17, 2020 10:44 AM
Fireslash
Apr 11, 2016 06:43 PM
wanext
Oct 6, 2015 12:18 AM
3.8TransAM
Oct 1, 2015 07:47 PM
tcflint
Sep 27, 2015 05:58 PM
