Water leak
Old Dec 14, 2002 | 03:21 PM
305TBI's Avatar
Car: 1991 Firebird Formula
Engine: 305 TBI
Axle/Gears: 4.10
Water leak
When it rains, and only when it rains, the front passenger floorboard carpet gets pretty wet. It is not caused from the heater core (I replaced it this past summer). I have tried to locate the water entry point, but I can't find it. There is no evidence of water on or under the dashboard nor along the side panel under the dashboard. The firewall carpet area is dry and around and in front of the console is dry. The only wet area I can find is the floorboard. Apparently rain water is getting inside somehow. Has anyone ever had a problem like this?
My car is a 1991 Firebird Formula with T tops, which have never leaked.
Thanks,
Don
Old Dec 14, 2002 | 03:32 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Check the weatherstripping on the door where the hinges are. Mine came off the door slightly and it was leaking.
Old Dec 14, 2002 | 03:51 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Does it happen when the car is sitting or when it's been driven in the rain? If it happens when driving, check the floorboards for rust through.
Old Dec 15, 2002 | 12:22 PM
MdFormula350's Avatar
yeah i would check under the car around that area to look for any problems, also check the window weatherstripping areas..
Old Dec 15, 2002 | 01:42 PM
305TBI's Avatar
Engine: 305 TBI
Axle/Gears: 4.10
Thanks everybody for your help.
BTW, the water accumulates in the floorboard while the car is parked in the driveway.
Don
Old Dec 15, 2002 | 01:49 PM
graywolf624's Avatar
I hate to usurp your topic, but I too just found a puddle. I was removing the rears seats and in the dip under them there was a puddle of water. No where else was the car wet. The car hasnt been driving in a month, but snow just was on it a week ago and melted. I plan to pay more attention next time it rains, but any suggestions on what to look for in the mean time is appreciated. It is too far back for the ttops or door it would seem, too far forward for the hatch. It is possible it leaked somewhere else and drained down since i have been in another state for a few weeks.
Old Dec 15, 2002 | 03:41 PM
305TBI's Avatar
Engine: 305 TBI
Axle/Gears: 4.10
Some of these water leaks are really a mystery. If I don't find my leak by just looking around, I will probably wait for spring and then put the garden hose on one section at a time and then inspect for water accumulation.
Thanks again everyone,
Don
Old Mar 23, 2005 | 11:16 PM
cozhavok's Avatar
Car: 1985 Camaro Z28
Engine: LB9 V8
I had a wet passanger floor so I took out all my interior and put a garden hose on my roof and found out where it was coming from. There is a wiring harness behind the passanger kick panel. That is where I found my leak. Now I just have to figure out how to stop it. My car also smells like mildew so I have to figure out how to get rid of the smell too. Any Ideas let me know.
Old Mar 24, 2005 | 06:53 PM
AJT86's Avatar
Car: 87 Buick Grand National
Engine: 3.8 SFI Intercooled Turbo
Transmission: 200R4 3000 Stall
i own 3 t top cars- and 2 of them leaked- new t top weather stripping cured the problem. on my 83 camaro the seals looked great- still leaked- once i put the new seals on it was dry. the grand nationals seals were just all brittle and cracked. sit in the car when it rains and pull your headliner out- check for leaks coming in. also if your headliner board is a little discolored that can be from water seepage.
Old Mar 24, 2005 | 07:43 PM
Alexcoqui's Avatar
Car: Trans Am "GTA"
The smell is a type of fongus that is alive. Put rubing alcohol in a spray bottle, & spray it on the carpets & seats (if they are cloth). do it every night untill you wake up the next morning & the smell is gone.
Old Mar 24, 2005 | 09:57 PM
GTA4ME's Avatar
Car: 1988 Trans Am GTA Notchback
Engine: 305ci, 5.0L, TPI, HO
Transmission: Borg Warner T5 5-Speed
Axle/Gears: 9-Bolt Positraction Rear w/3.45 Grs
I have the same problem. It's coming from your hatch. Mine was leaking from the window. It sucked.
Old Mar 25, 2005 | 03:24 AM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
I bet it's the front of the window where it starts to dip down from the roofline.
You ever roll your window down a crack while its raining, hit your wipers, then have a wet knee?
Yeah, that same spot. Sometimes I leave my window cracked a little by accident because it looks closed from the inside and that happens overnight if it's raining hard.
When you look at it from the outside you can see it's open about an 1/8th of an inch though.
Old Mar 25, 2005 | 01:57 PM
Biggwinn's Avatar
Car: 1986 Trans Am
Engine: 305 Carb
Transmission: 700R4 Overdrive
water leak
Ive had the same problem i took of the kick panel and ran a water hose to the windshield and it was comming from the wiring harness thats as far as i can tell. i jest need a way to seal it.
Old Mar 27, 2005 | 10:23 PM
cozhavok's Avatar
Engine: LB9 V8
I have been told to take out the harness but not remove the gasket and put sealent around the gasket then put it back in the wall then put sealent around the plug on the inside and outside of the plug and no more leaks.
Old Feb 24, 2008 | 08:16 PM
allgood's Avatar
Car: 92 WS6 Trans am convertible
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
Re: Water leak
i have the same problem, i read one post on here and the guy said that his problem was the vents, water was comming in from the wiper arm part which was getting in the floor vents
Old Nov 30, 2009 | 08:43 AM
jstuart83's Avatar
Re: Water leak
hey guys does anybody else have any incite on this problem i too am experiencing this i replaced the heater core last summer and the car only get wet when it sits in the rain, and only the passenger side
Old Nov 30, 2009 | 05:18 PM
goalieforlife's Avatar
Car: 1991 Pontiac Trans Am GTA
Engine: V8 305
Transmission: Automatic Transmission
Re: Water leak
mine gets wet on the driver's side
Bubbajones_ya
Jul 6, 2024 08:32 PM
92firebirdguy
Sep 1, 2016 07:53 AM
tommy z-28
Oct 6, 2015 10:58 PM
st.evel07
Sep 19, 2015 09:24 PM
84redta
Sep 19, 2015 09:58 AM
