Replacing antenna/Fender question
Old Dec 14, 2002 | 08:46 PM
J Kylez's Avatar
My power antenna is non-functional. I have a regular antenna assembly to install. Is going to be necessary to pull the entire fender off to do this? How should I go about this?
Thanks,
J
Old Dec 14, 2002 | 10:57 PM
deadtrend1's Avatar
You should get by if you remove the plastic liner thats in the wheel well above the tire.
Old Dec 14, 2002 | 11:42 PM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
i had to actually remove my entire fender to do it, just the plastic on the wheel well didnt do it..
Old Dec 15, 2002 | 07:19 AM
scott's85T/A's Avatar
This is another reason why I love my fender vents.
Old Dec 15, 2002 | 12:16 PM
MdFormula350's Avatar
i replaced my power antenna with anoter power antenna, i jacked that front passengers side up, took the wheel off, and then took the plastic inner fender think off.. and did everything from inside.. good luck
Old Dec 15, 2002 | 02:14 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
I have an original GM power antenna that I plan to install on my 84Z-28. It is now manual what will I need to do to change it to power? Is the original wiring in the car set up to take the new one?
Thanks in advance.
Old Dec 15, 2002 | 10:10 PM
J Kylez's Avatar
Thanks for everyone's replies. I was able to remove the power antenna and install the regular assembly no problem by just jacking the car and removing the tire and fender skirt. Although when I put the radio back in place it sounded like the relay triggered for the power antenna for about 30 seconds but I haven't heard anything since.
Oh yeah, I just cut the wires to the power antenna and wire nutted them.
Frozer!!!
Jan 19, 2024 04:55 PM
dutch930
Sep 11, 2015 06:58 AM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
Leggman1
Aug 6, 2015 04:15 AM
