Help With my Formula Headlights? broken mechanisms?
Old Dec 23, 2002 | 07:14 PM
bradkeith's Avatar
I am having 2 problems with the flip-up headlights on my project 88 formula. #1 One of my head-lights (drivers side) is completey broken, It just sits there loose, bouncing around, only mounted on the side opposite the motor, Looks like there is some broken fiberglass in there too. I know this is vague, but has anyone had something like this happen? It almost looks like someone tried to force it open by hand.
#2 The passenger headlight motor runs, but the headlight doesn't come up by itself. If i help it up by hand, it goes easy, but doesn't seem to want to stay up. I am new to firebirds.. is this a sign of my pop-up motor going out, or is it something else?
Thanks for your help, i am a newbie to firebird's headlights
I know this would've been easier to explain with pictures, but i didn't feel like taking a chance driving from my shop with those problems tonight . thanks again guys! brad
Old Dec 24, 2002 | 04:41 PM
bradkeith's Avatar
ttt anyone?
Old Dec 24, 2002 | 04:46 PM
83firebirdS/E's Avatar
Car: 1983 Firebird S/E
Re: Help With my Formula Headlights? broken mechanisms?
Yes that is the sign, your motor is going out. It's time for a new one. I have rebuilt them before and they never work as good as before and break easily. Check your relays as well.
Old Dec 24, 2002 | 04:49 PM
I'm not quite sure what you mean here. You might need a new assembly. Just remember to get a 85-90 assembly because they are different than 91-92 and 82-84.
Old Dec 24, 2002 | 04:50 PM
BlackBeast'88's Avatar
Car: '88 Formula
Engine: 355cid
us this link below. this guy actually has pic and everything. I repaired my drivers headlight on my '88 formula and it works great.
http://www.transamtemple.com/modific...ght_repair.htm
Old Dec 25, 2002 | 12:11 AM
bradkeith's Avatar
Re: Re: Help With my Formula Headlights? broken mechanisms?
I got the car to my house tonight and looked closer at it. ok... There is about a 3 inch piece of fiberglass still attached to the headlight motor arm on the driver's side, like the whole bucket is broken? I'll have to go to the 'yard this weekend to see what i can find there. thanks 83firebirdS/E for your help, brad
Old Dec 25, 2002 | 01:06 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I manufacture the repair kit to fix the 1987-92 Firebird headlights. It is under the Body & Interior category. You can also download the installation instructions from the Instructions section of the main page of the web site. It will give you more information about what is causing the problem (bad gel inserts) and how to repair it.
Lon Salgren
Jorlain
Aug 24, 2022 05:11 PM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
theshackle
Mar 5, 2017 06:37 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
gwade12
Aug 8, 2015 08:17 AM
