Third Brake Light (glass mount)
Old Dec 23, 2002 | 08:48 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
Dont know if anyone has done this, but thought I would tell everyone anyway. I have an 84Z-28 and I wanted a glass mounted 3rd brake light (the correct one). My car did not come equiqqed with the light, but I like the look of it. I bought a new light and ground off the brass screw mounts on the back side and siliconed the light to the glass and hot wired it into the brake lighting system. It looks great and I did it without worrying about the missing holes in my glass.
Old Dec 25, 2002 | 02:46 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
You're probably the only person in the world that wanted the outside mounted brake lite. I do like mine because it is different and only made in '86.
Old Dec 26, 2002 | 04:20 PM
MartyMcFly's Avatar
Car: Z28
Engine: Edelbrockified 305
Transmission: 700-R4
NOT TRUE! I have also thought of doing this. With all these SUV's running around, i figured i'd make it easier for them to see me so i don't get rear ended. I gotta know, yankeecarman, how did you run the wire(s) into the interior?
Old Dec 26, 2002 | 04:50 PM
Freeze's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
i prefer the 91/92 style behind the glass
Old Dec 26, 2002 | 04:54 PM
from the third brake light into the hatch area from the top. Went between the hatch and the gasket and no it doesnt leak. I touched up the bit where the wire comes from the light with a little black rubber sealand to keep water from entering the third brake light. I am very impressed with the results. Looks factory.
Old Dec 26, 2002 | 09:24 PM
83firebirdS/E's Avatar
Car: 1983 Firebird S/E
I have thought of doing the same thing except with a long narrow LED strip inside the top of the rear window like in the 02 Olds Aurora.
Vintageracer
Jan 10, 2020 05:33 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
BrianI
Aug 9, 2015 11:52 AM
