Inner Handles Help Needed ˇˇˇˇˇˇˇplease Im Serious
Old Jan 4, 2003 | 12:04 PM
Calderone's Avatar
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
Hi guys i hope some of you can help me
My two inner handles are broken...and here in Chile i cant
find any inner handle for thirdgens ˇˇˇ
Is there any other GM car that uses the same handles apart
from the FIERO and FBODY?
PLEASE IF SOME OF YOU HAVE TWO INNER HANDLES
IN GOOD SHAPE AND WANNA SELL
PLEASE PM ME CAUSE MY CAR COULDNT PASS THE
TEST HERE IN CHILE AND I CANT DRIVE IT ONLY FOR
THE HANDLES
HEEEELPPPPPP
THANKS ˇ
Old Jan 4, 2003 | 07:10 PM
Camarokid01's Avatar
look on Ebay they usually have a bunch of new ones and used ones.
Old Jan 5, 2003 | 07:59 AM
Calderone's Avatar
Car: 87 Vette
THNX
Thanks but i dont wanna win a bid ...
i wanna make a direct trade or something ...
if anyone can help me i will appreciate it a lot
really thnx
Old Jan 5, 2003 | 10:36 PM
Calderone's Avatar
Car: 87 Vette
what are they made of ?
what are handles made of ????
i need them tomorrow....
can they be welded ?????
Both are broken but i need to pass the revision test.
im gonna weld them as urgency..but ..
i dont know if its possible or not ?
Old Jan 6, 2003 | 06:28 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
I believe Grand Ams from 85-91 used the same inner door handles.
Old Jan 6, 2003 | 09:21 AM
The handles are metal but there is a spring type thing inside and I think that is the thing that brakes if your door handle works like normal it just wont open the door then the spring is broken but if the handle actually fell off, you could probably weld it.
Hope that helps
Old Jan 6, 2003 | 08:23 PM
EvilCartman's Avatar
Car: '82 Z28
The rod connected to the handle on mine actually had worn right through where it connected. Pulled the handle one day and it broke
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
sreZ28
Aug 14, 2015 07:48 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
