interior teardown
Old Jan 10, 2003 | 04:49 PM
Eat_um_up's Avatar
interior teardown
i have a couple of things i want to do and im wornderng just how doable they are. so any help would be appreciated.
I have an 85 firbird and a 82 trans am. i want to put hte center console from the trans am in the 85 firebird (couse i like the shifter better) and put the seats from the T/A in the Firebird. I noticed that the rear seat in the firbird splits into two sections. can i still put that one piece unit from the T/A in the firebird?
I also want to change the front fenders. will they bolt up from the '82 T/A on the '85 firebird?
after which i am parting out the T/a and the remaining parts from the firebird that i took out.
James
eat_um_up@msn.com (if your looking for parts) the T/a has a goood 305 v8 and new rebuilt never used tranny
Old Jan 10, 2003 | 05:17 PM
Abubaca's Avatar
I'm not certain about these facts, but I'm pretty sure the sheetmetal was the same for all 10 years. So the fender should fit.
The split rear seat has a bracket welded in so the center of the seats have a hinge, so the split seat won't swap out into the other car unles you weld in that bracket. Vice versa however, I can't see why you couldn't use the solid seat in either car?
Old Jan 10, 2003 | 06:07 PM
Eat_um_up's Avatar
I want to put the solid seat in the 85. I am junking the 82. so will that bracket get in the way?
Old Jan 10, 2003 | 06:19 PM
Abubaca's Avatar
Ahhh, good question. I wouldn't think so, but it might. You could always cut it off.
Old Jan 10, 2003 | 09:37 PM
Camar92's Avatar
Car: 1986 IROC-Z
Engine: Vortec 350 with mild cam
Transmission: 700r4 Mild build
Axle/Gears: Stock
Everything is dueable in our cars. It may take a bit of mods but just think hard, long, and ya know what, anything is possible. Good luck man.
Old Jan 10, 2003 | 10:44 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
You can do everything your talking about doing. If you want to add GFX then you may have to do some drilling. Also I am looking for interior parts. I have an add in the classifieds section about it. But I would like to ask what condition is the interior stuff being left in the car you are junking? And what color is everything?
RyanJB
May 7, 2016 06:23 PM
codeysabatini
Sep 20, 2015 11:36 AM
MORREALE5
Sep 13, 2015 09:01 PM
sylentnite
Sep 9, 2015 02:55 PM
