How to remove scratches in the interior plastic??
Old Jan 10, 2003 | 11:29 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I'm just wondering if anyone knows of a good way to get rid of and smooth scratches in the plastic. The interior pieces are pretty good but a lot have scratches in them.
Thanks for the help.
Ed
Old Jan 12, 2003 | 11:12 AM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Theres a paint o the market that will do a good job of that. It is somewhat scratch resistant. It costs like $7.00 a can. I have been told it takes about two cans to do all the interior plastics. I don't remember the name of the product though. Somewhere I might have the address of the shop that sells it. It's in Texas though.
Old Jan 14, 2003 | 02:55 AM
irocEOK's Avatar
yea, use mothers aluminum polish. metal polish is abrasive enough to take
out the scratches but not add any. A trick i picked up after working on
planes all day.
Attached Thumbnails How to remove scratches in the interior plastic??-fullsizeblazereok.jpg
Old Jan 14, 2003 | 04:38 AM
ctandc's Avatar
The plastic GM used for the interiors was pretty cheap stuff...but using some assorted scotchbrite or drywall sanding pads of different grit can help get most imperfections out. I've always had better luck wet sanding the interior stuff.
Then head to the local Auto Paint and Body Supply store and pick up some vinyl / plastic prep, thinner, and some SEM vinyl / plastic dye. They can match any factory color from the interior RPO Code, and most can even put the stuff in small spray bombs for you. They also use an adhesion promoter for this dye, I've had good luck with it and without it.
The trick is to have the surface as perfect as can be, no dust etc. Then spray the dye on in THIN coats.
HTH
Old Jan 14, 2003 | 07:51 AM
ebmiller88's Avatar
Thanks for all the hints, guys!
ED
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
anesthes
Mar 10, 2016 10:35 PM
3rdgenparts
Aug 8, 2015 07:09 PM
