How to remove console?
Old Jan 11, 2003 | 02:08 PM
Abubaca's Avatar
OK, with all the 4th gens swappers on here, this should be a simple task for you guys.
I've got the shift plate off, and the Ebrake handle, but I still can't get the upper console past the Ebrake! Does the WHOLE handle need to come off? If so, how do I remove it?
Please help!!!!!!!!
Old Jan 11, 2003 | 02:19 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
You should be able to pull the hand brake all the way up and slide the console up the shaft of the lever and have it off in seconds.
Old Jan 11, 2003 | 02:52 PM
Abubaca's Avatar
My Ebrake doesn't come up more than at 45 degree angle...maybe a little more. It's real tight. How do I loosen it?
Old Jan 13, 2003 | 03:54 PM
Camar92's Avatar
Car: 1986 IROC-Z
Engine: Vortec 350 with mild cam
Transmission: 700r4 Mild build
Axle/Gears: Stock
you could take off your back wheels, spin off your drums and take apart your braks, making it possible for the e brake to be pulled the rest of the way. Other than that, see if there is a way to loosen the cable any other way. If that way doesnt work, try lifting the upper part up, then spin the console sideways, then lift the part out. This is what worked best for me. I think you can unbolt the ebrake, but im not sure on how hard it is to put back, thus with all the tension. Plus, the fourth gen console has no room to bolt the ebrake back in.
Old Jan 13, 2003 | 10:03 PM
Abubaca's Avatar
Well, I've got 4 wheel disk, but I suppose the same idea applies.
I tried the twist idea, but that didin't seem to work.
I know there's some sort of tensioner for the Ebrake underneath somewhere? Hmmmmm....
Old Jan 13, 2003 | 10:20 PM
BOTTLEDZ28's Avatar
Transmission: A4
Getting the console up over the E brake handle can be tricky. You just have to work with it. I pulled my handle up as much as i could with 2 hands and then lifted the console up and twisted it around away from the dash. Make sure the switches are unplugged or you wont get very far also, the plastic can bend a little but not much and the temp of the plastic will determine how flexible it is. if that still dont work then you can disconnect the cable from under the car as stated above. either at the wheels or under the car right above the driveshaft
Old Jan 13, 2003 | 10:50 PM
Abubaca's Avatar
Oh yeah, and let me tell you how much fun unplugin' the switches with cold hands was!!!
I'm just gonna unhook the cable.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
88HARDTOPIROCZ
Sep 18, 2015 10:30 PM
Fronzizzle
Sep 8, 2015 12:10 PM
