Power attenna broken??
Old Jan 13, 2003 | 08:32 PM
DRedIROC87's Avatar
My power attenna has never worked since ive bought the car and i think it is time to change it in my 87 iroc. I was wondering how to come about this?? does the fender have to come off?? is it easy to accomplish this? is it hard to change the attena itself ??
żż
thx
Old Jan 13, 2003 | 09:09 PM
MdFormula350's Avatar
jack up the car in the front passengers side, use a jack stand..
than take the rim off, and then take out the inner plastic fender well, as much as you can.. then look inside and just a couple of bolts...
did the motor burn out?
does it up up or down?
it is getting power?
https://www.thirdgen.org/techbb2/sho...ntenna+rebuild
Old Jan 13, 2003 | 09:18 PM
DRedIROC87's Avatar
the power attenna doesnt do n e thing just sits there....how does it work?? does it go up and down as the car starts or radio turns on?? it has never worked so i have no idea. As for pulling the rim and taking out the inner fender that sounds easy i will have ta try it
Old Jan 14, 2003 | 11:08 AM
well i have mine come on when the radio is on. i think the stock radio's also have a power button and when that turns on the antenna should go up...
Old Jan 14, 2003 | 10:00 PM
SLP-GTA's Avatar
Car: 1991 Formula (sold)
hey what is the GM replacement part number?
I think GMparts online has them complete for around 70-80 bones, anyone have the link?
Old Jan 14, 2003 | 10:07 PM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
Power antenna
Check the relay first. Under the passenger side front panel in the interior. It should have a green, a grey, and a black wire if I'm correct.
Mine was burnt. I replaced it with one from the bone yard and it worked fine.
Old Jan 15, 2003 | 06:41 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Like Jim Berry mentioned, check the relay first. You may save yourself some time and trouble. As I recall (someone jump in if this is incorrect), when you turn the radio on, you should hear a click from the relay (put an ear to the pass side dash panel near the IROC-Z badge). If not, then, I believe, you've found the problem. The 'Car Audio' board might provide more answers.
JamesC
Another thought: If your car has ever had an after market radio, the relay may have simple been unhooked.
BRoss99
Aug 10, 2025 05:08 PM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
sailtexas186548
Aug 24, 2015 10:11 PM
