91-92 nose on 86 iroc.. can it happen?
Car: 86 IROC-Z
Engine: 406
i am getting my car painted here soon and need some new psrts for the car. i like the GFX of the 91-92 3rd gens vs the 85-90's. im just wondering if the nose from a 91-92 will fit on my 86 iroc.
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Yeah, it will fit....but why change the whole nose? All of the noses are the same from 1985-1992 IROC-Z/Z28/RS. The only difference from the apperance of your 86 Iroc front nose and the 91-92 Z28 noses are the bowtie grill and the ground effects.....the noses are the same....so..all you would have to do is change the grill and the ground effects.....that would be a lil easier then changing the whole nose...just a thought...
Car: 86 IROC-Z
Engine: 406
true.. that would be much easier to do. and i would if i just wanted the different gfx... but i had a booboo in the car a few months back and the nose of the car is all beat up. *not that bad.. but if im going to be painting the car, id liek to have it fixed*.
Someone correct me if I'm wrong here but I thought I had heard that where the 91/92 gfx bolted up to the nose were different locations than the earlier nose so you needed the 91/92 nose for the 91/92 gfx.
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Engine: 5.7
the 91-92 Z28 ground effects will bolt right up....as long as its a 1985-1992 Z28/Iroc-Z/RS front nose. I have done it many times.....
