i know i'm gonna get flamed but....
Old Jan 30, 2003 | 03:37 AM
89-28gp's Avatar
Car: 1986 Firebird
Engine: not stock 2.8
i'm probably going to get some brutal "soccer mom" comments for this one, but here it goes.
my first child was just born yesterday, and i was wondering if anyone has ever installed the clip necessary for a forward facing seat's harness to hook to in a 3rd gen? if so where? the gas tank is below and right behind the rear seat, would it have to go on the floor in the t-top well?
i'd hate to have my son restricted to driving in only the blazer until he's in school
Old Jan 30, 2003 | 06:22 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
CONGRATS!!!!
i have no idea about mounting the thing (no kids here)
but i surely hope NO ONE would give you any flaming about this thread.
at least you aren't selling your f-body for mini-van or anything!
Old Jan 30, 2003 | 06:42 AM
MarkB's Avatar
Car: 1982 T/A -1986 Z28
Engine: 383 -305
Transmission: T56-700r
[/B]
LMAOOOOO! hey dewey...i would have to asume you dont have kids becuase you have no idea how to mount the thing?
lmao j/k bro
as far as the seat carrier...i thought they just attached by using the seat belt? i could be wrong though...if you can give me a general idea how they attach..i can try and help you figure out how to get them to fit i nthe 3rd gen.
Old Jan 30, 2003 | 06:46 AM
Dewey316's Avatar
Car: 1990 Camaro RS
is that the best you could do with that comment?
guess its because i don't have a buddy like tony with practice with!!!!
anyway, lets not get this thread locked for the guy with a real question.
Old Jan 30, 2003 | 06:53 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Congratulations, man are things gonna change now. We had our daughter 18 months ago and I was just like you with all the new stuff. Especially the car seats. Only the newer cars actually have the place for the clip to clip into. We had a 93 Saturn SL and traded for a 2002 Malibu, it was'nt till we got the malibu home I realized what that strap actually was for and what it clipped into. Until we traded we just used the plain seat belt and then used the seat belt clip to hold it in place-that funky lookin H shaped thing. I guess you could weld a tab in the cargo area of your car for the hook, but really should'nt need it. Good luck
Old Jan 30, 2003 | 07:00 AM
Demon Z28's Avatar
Car: 2001 Camaro SS
Engine: Almighty LS1
I would think that theres enough clearance between the floorpan and the gas tank for you to mount them at the top of the hump... just a guess however...
are you going to get him one of those spiffy 5 point harnesses for children from summit?
Old Jan 30, 2003 | 07:36 AM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
A common mounting point is to use the lower seatbelt attachment point under the rear lower seat cushions. Make sure that the bolts still thread in far enough after going through the new bracket holding the child seat clips, otherwise get slightly longer bolts.
With the forward facing seats, there's often a third attachment point going back toward the rear deck or hatch area from the top edge of the seat to keep the top of the child seat from rotating forward and into the front seatbacks. That would take some custom work to get done in the hatch. Make sure that it goes through more than just thin sheet metal though, like the thin sheet metal above the gas tank would be bad. Get on a portion of the rear frame area or a suspension mounting point or something else integrally sound. Look at it this way... you guys just had a kid and you get to show him how to use a power drill already!
Old Jan 30, 2003 | 08:10 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Congrats! Nobody is going to call you a soccer mom because you're concerned for your kid's safety in your thirdgen. Anyway... since it's mostly all sheet metal back there, I would suggest that however you decide to mount it, that you put a steel plate on the other side of the sheetmetal so that the mounting bolt doesn't just pull through in an accident. This might get difficult though, because there probably isn't enough clearance above the gas tank, and the rear tail light area is double-panel. Your best bet might be to go between the upper and lower seat cushion directly into the backside of the gas tank hump, but you'll have to look at the tank to decide if there's sufficient room. You want to leave enough room so that if there's a collision, the bolt doesn't puncture the gas tank.
Old Jan 30, 2003 | 10:58 AM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
you just need a hook thing for the child correct??
well on my iroc there are small hooky things for the t-tops bag. cant u use those if u have t-tops
Congrats by the way.
Old Jan 30, 2003 | 11:24 AM
88txiroc's Avatar
I am happy to see another thirdgen person wanting to keep the kids safe. You will not get flamed in this post, I will see to that!
As Ham said, you can use the t-top mounting point right behind the seat or the one on the rear hatch area. Even if you car does not have ttops, the points are still there. The only thing you would have to do is go to a j/y and get one of the little "u" shaped things and the screws and it should fit right in. HTH and GL!!! Thomas
Old Jan 30, 2003 | 11:44 AM
82camaro's Avatar
Car: 82 camaro SC
It's not required. You can go without if you tighten the seat belt really good. Here is some information on the subject.
http://www.nhtsa.dot.gov/people/inju...UR/TechW99.htm
http://www.actsinc.org/83199.cfm
http://www.keepkidshealthy.com/welco...ety/latch.html
Old Jan 30, 2003 | 09:21 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Could always try going as far back as the taillight panel, too. You'd have to cut a notch in the rearmost hatch cover panel, against the taillight panel. Remove a taillight, drill some holes to mount the clip. When you screw the bolts in, use locktite so the nuts don't loosen, and squirt black silicone along the head of the bolt so water doesn't get in. Plan the holes well, so you can reinstall your taillights without hitting the clip screws.
Then cut a notch in the rearmost hatch cover panel to allow the webbing to poke through. If you wanted to hide the hole, you could always put carpet on the outside of the hatch panel.
Old Jan 31, 2003 | 06:03 PM
89-28gp's Avatar
Car: 1986 Firebird
It actually is required.... different restrictions in canada. talked to a police man friend of mine to confirm. we just have a rear facing for now, which is ok to just go with the seatbelts, but the front facing we'll need when he gets older needs the harness & clip.
so there's small hooks in t-top cars back there? anyone have some pics of those so i can get a better idea of where & what?
the blazer already has a hook for it in the rear cargo area, wish it was the bird tho, cause it would be a snap to get one in the truck
the thridgen is definately not going for a van tho, the wife hates them even more then me
Old Jan 31, 2003 | 06:20 PM
HamSpiced's Avatar
they arent necessesserily hooks but they are small loopy things that the t-top bag hooks to. it is right on the hump where most people mount their amps.
Old Jan 31, 2003 | 07:45 PM
razor's Avatar
Car: 1992 GTA
Axle/Gears: 4.10
HamSpiced
their amps.
.....hmmmm....small loopy things that the bag HOOKS to????? Maybe they are hooks after all????
Old Jan 31, 2003 | 09:39 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Another way is to weld in a bar accross the rear of the car. Right behind the top of the rear seats.You'd have to trim your int panels a little bit. Then you can run some belts to the safety seat. Heres a quickey pic. I had to edit, I had put you had to take out the rear seat which you obviously dont
Attached Thumbnails i know i'm gonna get flamed but....-rearcompartmentforsafetyseat.jpg
Old Jan 31, 2003 | 09:57 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
my owners manual says that in 89 even the hard top cars got the t-top mounts for the canada cars so the safty seats could be used.
thanks
anthony
Old Jan 31, 2003 | 11:24 PM
HamSpiced's Avatar
Originally posted by razor
HamSpiced:
um.... you dont hook hooks to hooks. they are just like i said loopy things. they are holes that hooks latch to.
Old Jan 31, 2003 | 11:37 PM
88txiroc's Avatar
It is dark out right now, but I will post pics of the "loopy thingy" in the morning.
Ham is right about not hooking hooks to hooks.
Old Feb 1, 2003 | 12:16 AM
Kandied91z's Avatar
why does it have to be forward facing...........perfect excuse for at least a 4 point roll bar!
Old Feb 1, 2003 | 07:45 AM
TimRS's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Congrats! When my daughter was born, I had no problem with her infant seat attaching with that "h" clip in the back seat. It can be a pain getting a baby that small out of that tight back seat area though. She is 4 now and loves to ride in daddy's Camaros...especially the 5-speed.
Old Feb 1, 2003 | 11:12 AM
igotslicksNchix's Avatar
i was at k&s the other day (local speed shop) and saw THE car seat....simpson racing seat with 5 pt racing harness, looks like the real thing, but for the lil' ones. I'm definately saving up for one for my soon to be nephew or niece!
92projectcamaro
Dec 8, 2015 12:25 AM
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
2012sergen11
Oct 13, 2015 07:38 PM
91 SrS
Oct 7, 2015 04:32 PM
Vincent135
Sep 28, 2015 10:50 PM
