Making a Hatch Release ????
Old Feb 2, 2003 | 10:21 PM
skahide's Avatar
I have a 88 Camaro and it had no power options. I want to add a hatch release though. How do i go about doing this? I have heard that all you have to do is add a wire from a power source, it goes to the relay (under the middle consol and i have to purchase?) and from there have a wire go to the hatch motor. Is that right? Anyone have an easier way? Thanks for any input.
Old Feb 2, 2003 | 11:33 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Tommorow I'll take a pic of mine.I installed one into my 85 SC. The install is pretty strait forward. You need the console wiring harness,a hatch release switch, and the release silenoid from any camaro,or bird. If you get one from a 82-85 then you can get the whole release mechanism, and if you get 86-92 release you just need to pull off the silenoid. The connector for the release swith is already in the center console you just have to plug the harness in. Put you silenoid on your release thats already in the car or the whole unit from another. Bolt it on and put the ground wire on and run the long black wire to the centerconsole wiring harness. Then you should be able to pull back on your hatch release and hear the great click.
Old Feb 2, 2003 | 11:34 PM
Car: 85 Camaro SC
Engine: V6
Oh and welcome to the boards. Stick around here and you can learn lots of great and usefull information about our 3rd gens.
Old Feb 3, 2003 | 08:20 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
The solenoid from most any late-model GM (say78-up) will work, and should be easier to find.
Old Feb 3, 2003 | 09:20 AM
skahide's Avatar
Thanks for the info and the welcoming to the site. I have been looking in here for months but finally realized that i should join. You guys kick butt.
Old Feb 3, 2003 | 01:32 PM
Car: 85 Camaro SC
Engine: V6
Heres what the sileniod looks like. Dont mind the dirty hatch area you can see where I had to silicone up my weatherstripping to stop dust from comming in to my car.
Old Feb 3, 2003 | 02:43 PM
skahide's Avatar
Cool, thanks for the pics. They always help. So all i need to buy is the siloniod? and then bolt it in? and what would the siloniod # be? thanks again.
Old Feb 3, 2003 | 03:19 PM
Car: 85 Camaro SC
Engine: V6
I have no idea about the part #'s but all you need to do is get the sileniod and theres a metal tab thats on the release where you bolt the silenoid on. You just have to get some pliers and pull the tab up so the silenoid will bolt on.
Old Feb 3, 2003 | 03:50 PM
84'fxrupr's Avatar
what is the console wiring harness? i was thinking of doing this as well. I also wanted to do power windows and door locks but i can't find the site anymore. can anyone help out?
Jared
Old Feb 3, 2003 | 07:01 PM
Car: 85 Camaro SC
Engine: V6
Its a harness that hooks up to your original wiring harness under the console. Your camaro already has a harness with some unused connectors in the console. The one you need to get from a donor car has a connector on one end, another to connect to the hatch release switch, a relay, and a wire that goes all the way to the release silenoid. Its basically a bolt on addition to any camaro or bird.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
neekolzun
Aug 24, 2015 04:59 PM
madsv1000
Aug 20, 2015 06:45 AM
smooth
Aug 18, 2015 06:34 PM
z28addict8490
Aug 7, 2015 08:48 PM
