digital climate control
Old Feb 3, 2003 | 12:28 PM
BryanJ's Avatar
Has anyone tried to put a digital climate control module like from a buick, olds, tahoe etc... into thier camaro or bird. Is this even possible, I am thinking about trying it out since i have digital gauges it will prob look pretty good. Just thought I would ask around first
Old Feb 3, 2003 | 03:35 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
i would assume it would be a huge pain, the hvac in my car is mechanical. dont see how you could ever put something digital in its place without changing a lot of parts. i have no idea really though, might be possible.
Old Feb 6, 2003 | 10:52 AM
jawzforlife1's Avatar
I belive the orig controls work on cables (that is how my chevy truck works), when you move the lever it moves the cable. I dont think the electric controls work the same way.
Old Feb 6, 2003 | 10:59 AM
IROCKER's Avatar
I'm sure some how it's possible...the only trouble is most of the newer HVAC and fancier digital setups used vacuum to control the vents.
Old Feb 6, 2003 | 11:04 AM
right, and you cant hook up the orig controler (that uses calbe) to the vacume hoses. you wuld have to find a way to change all the cable connections (from the control to the vents) to vacume lnes.
Old Feb 6, 2003 | 12:50 PM
quadgoat's Avatar
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
I dunno guys, but my '84 TA uses vacuum to control the vents. The only cable is for the hot/cold control. So maybe it wouldn't be that hard? If your car is shut off and you move the control from say, a/c to off, you'll hear a hiss, that's the vacuum moving the vent baffles. I know mine wouldn't change after I put my new motor in because I didn't have the vacuum canister hooked up right. Once I hooked vacuum up to the system properly the vents would change again. Correct me if I'm wrong here, but I don't think it would be all that hard
-Paul
Old Feb 8, 2003 | 12:44 AM
CanadianCamaro's Avatar
Car: 1992 Camaro RS
Engine: 5.7 V8 TPI
Transmission: T-5 5-Speed Manual
I was actually trying to figure this same thing out myself....
My brother has an 84 Berlie with the digital dash, but the cluster is dead, we're going to swap over to the 82-90 dash & I'm trying to figure out how to use Buick controls with the Berlie's electronic heater box.
If I can get the schematics for both heater boxes I should be able to get something working (I Hope)
Old Feb 8, 2003 | 12:23 PM
PopaPork's Avatar
(Jim 86 Bird on Popapork's login)
You guys might wanna try getting in touch w/ some of the people on the boards that either own GTAs or TAs with the digital cluster in them, or people that have converted to the digital cluster.
I believe the climate controls are digital as well when you convert to the cluster. There's even a separate section in my 86 and 88 shop manuals that explains it all. Sorry I can't look it up right now b/c I'm away from home.
Hope that tidbit helps
Old Aug 7, 2005 | 12:35 AM
swimster's Avatar
Car: 99 Subaru, 92 GMC Van, 95 Bonnie
Engine: LOTS of them
Transmission: LOTS of those too.
piece-o-cake...
ALmost done with this conversion.. It's alot easier than you think.. seriously.. just need ot get the right parts from donor car.. but easy none the less..
Old Aug 7, 2005 | 01:55 PM
astoria18's Avatar
Car: 1985 Trans Am
Engine: LB9
swimster- care to elaborate? That looks really good, what kind of work is required to get that done?
Old Aug 7, 2005 | 06:00 PM
tagta189's Avatar
The digital clusters actually use an electric motor assy to switch the vacuum to the various vents and such,good luck getting one though.I tried to repair one of those quite a few years back on my 87 gta and everything was NLA even back then.
Old Aug 7, 2005 | 06:37 PM
swimster's Avatar
I have 2 of these "servo boxes" from 2 different cars.. there's actually several different variations of this system. Mine is by far not from a camaro or firebird.. untill today after doing some more reading, I had never heard of these cars ever having digital climate control. But however, with the right wiring diagrams from the car I got this stuff from and the diagrams for my bird, this is an extremely easy task. both boxes I have work great. these systems are all over the place int he bone yards. just look int he caddy's and buicks and olds for the controls that suit your tastes. As far as the face plate goes, I just widened the upper hole to accept the digital controls. Do they have a face plate that is already wider in the upper hole? I've never seen an actual factory F-body climate control setup.
Old Aug 7, 2005 | 08:41 PM
CamaRod's Avatar
Car: 91 Camaro RS
Engine: 305 TBI, (right now)
i was actually thinking of doing the same
my plan was to get a new CD player and put it in the old AC control slot
then put the digital climate control system in the old radio/ tape player hole.
My dad used to drive a 92 buick le sabre, im pretty sure that unit would fit almost perfectly in the old radio/tape player hole, with little modification needed.
the only thing i was worried about is all the connectors, may it be vacuum or wire connections.
let me know how you guys do on your conversions before i change around mine
i guess i dont really use the AC any way, but i do like my heat
Old Aug 7, 2005 | 08:54 PM
swimster's Avatar
I've got a smaller sized GM Delco CD player that I'm going to put in place of the ashtray in the console. I'll try to get some pics of this as I go along. All you need is wiring diagrams and hook them up accordingly.
Old Aug 7, 2005 | 08:57 PM
CamaRod's Avatar
Car: 91 Camaro RS
damn using the ash tray is a good idea
but i would probably put in like an equalizer
Old Aug 7, 2005 | 09:01 PM
swimster's Avatar
Only reason I'm using the Delco stuff is to make it look like it was factory installed. I duno why, but I got a stupid thing for that. Not to mention, I like the look of these radios and controls. Now All I need is a digital GTA dash to complete the look. I have a small all black LCD panel I thought about installing somewhere, but not sure where i'd like to put that.
Old Nov 23, 2016 | 02:26 PM
EnglishFirebird's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.1 v6
Re: digital climate control
Ridiculous thread resurrection I know - but if Swimster is still lurking here, I want to re-create this - could you let me know which car the servo boxes came from please? Cheers, Alex
Old Oct 12, 2018 | 07:10 PM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
I am currently attempting this, i have the display, programmer(vacuum box/HVAC computer) outside temp sensor, inside temp sensor, sun sensor and resistor set out of a 1995 Bonneville. it dosent look that hard, I was going to mount the blend door motor near the blend door bellcrank and make a pushrod for it, the vaccume looks pretty straightforward and so dose the wireing (with vacuum and wire diagrams for both vehicles), the only prob i have is the junker boniville i got everything out of dash was tore up, and the blend door moter was smashed, autozone wants $70 for it, dose anyone know what cars have the same blend door moter so i can get one from a junker?
gixxer92
Apr 12, 2022 12:09 AM
Elephantismo
Feb 13, 2019 12:51 AM
1992Z28!
Nov 19, 2015 07:33 AM
MantyZ28
Nov 8, 2015 06:54 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
