Modifying fender to fit convertible...
Old Feb 12, 2003 | 01:21 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Does anyone have the shop manual/technique for modifying fenders to fit convertibles? The lower brace behind the tire needs to be removed, and a b race needs to be added infront of the inner door. All this being on the acual fender itself.
Old Feb 12, 2003 | 07:13 PM
Anyone?
Old Feb 14, 2003 | 04:47 AM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
DO oyu mean quarter panels? cause the fenders are in the front and the dog house is the same between converts and hard tops...
Old Feb 14, 2003 | 07:43 AM
Nope... where the bottom rear brace of the front fenders bolt up on standard cars has to be removed due to the chassis supports of the convertible. Ill see if I can get some pics.
Old Feb 15, 2003 | 07:21 AM
Cronic3rd's Avatar
Car: 98 Z28 vert
hmmmm interesting....
Old Feb 15, 2003 | 09:23 AM
patrickm00's Avatar
yeah, they are different. i have a coupe fender and a convertible with a dent, but when i was doing the GFX change, it was getting late (and cold) so i decided to save the fender for later. but i did notice that the bracket is not at the bottom, but coming out from the inner surface of the fender near the door.
the best thing to do might be to have a shop weld the old brace or a suitable replacement if it's not very complex (i don't remember) into the new fender and then cut off the bottom one
Old Feb 15, 2003 | 01:15 PM
badandy247's Avatar
Car: 91 Camaro RS
Engine: 3.1L V-6
Transmission: Fresh 700R4
There is a guy on the boards (can't think of his name for some reason) that converted his hardtop to t-tops then to a convertible it is pretty tricked out flames and the works he would be excellent to attempt to contact for info on this.
Old Feb 15, 2003 | 02:08 PM
Your thinking of Fatal88. 2 problems with that: 1, he's acually using the entire front end of a 4th gen, but has 3rd gen fenders on it. 2, beings that he converted his car to convertible, he doesent have the factory bracing that gets in the way, which was put there by ASC.
Old Feb 16, 2003 | 02:11 AM
badandy247's Avatar
Car: 91 Camaro RS
Engine: 3.1L V-6
wow i didn't know he had all that in his car, somewhere i had heard something about him using a couple of convertibles for the parts to do his conversion i just thought maybe he knew a little about this subject.
Frozer!!!
Jan 19, 2024 04:55 PM
evilstuie
Apr 14, 2016 08:52 PM
deracer
Apr 11, 2016 12:04 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
theurge
Aug 21, 2015 12:46 PM
