stupid seatbelt thingy
Car: 89 Camaro I-Roc z
Transmission: Th700r4
My stupid seatbelt thing tha tis hooked into the headliner on both passenger and drivers side always slides down the seatbelt. the little plastic clips on them broke and i was wondering what have you guys done to fix this if you have? to replace it how do i do it without cutting th enew plastic piece?
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
take some rubber glue and glue them up there. this glue is sticky enough to last but will let go if the piece need to be removed later on.
thanks
anthony
thanks
anthony
Car: 1987 "1991 Z" Sport Coupe
Engine: LG4
Transmission: TH700R4
ok, sorry to but in but it is in the same topic.....maybe u can help me out....the area in the headrest where the seatbelt guide is striped and loose......any ideas how to fix it....? thanks
get some type of plastic epoxy (like duramix) and shoot some into the headrest holes. then after it hardens, take a drill bit a little smaller than the shank of the screw, then drill the holes a little longer than the crews. then screw them back on like normal
thanks
anthony
thanks
anthony
you can glue them, or you can buy a set of new ones for about $7.50. You just have to break your current ones to get them off, but the new ones come pre-cut so they just slide in and snap on.
thanks
anthony
http://www.thirdgenresource.com/inc/pdetail?v=1&pid=527
$7.50 + shipping, already pre-cut, black or grey
xbazzarex
Dec 1, 2015 05:25 PM
