Question for those who've installed 4th gen consoles
Old Feb 24, 2003 | 05:03 PM
Wootah's Avatar
Car: 88 Iroc-Z
Engine: 355ci
Transmission: WC-T5
Ive got mine in, and I've had it in. The middle and the back seems to sit fine, but the front just wont lay flat. It sticks up alot on the right side, and a lil on the left side. Is it just me or oes everyone have this problem, and how should i fix it? Thanks.
Old Feb 24, 2003 | 09:04 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
got a picture?
Old Feb 24, 2003 | 10:22 PM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
If u notice the passenger side will stick out a little due to the shape of the console naturally.
Old Feb 24, 2003 | 10:37 PM
Wootah's Avatar
Car: 88 Iroc-Z
Engine: 355ci
Transmission: WC-T5
pictures
Wootah's Avatar
Car: 88 Iroc-Z
Engine: 355ci
Transmission: WC-T5
Old Feb 24, 2003 | 10:38 PM
Wootah's Avatar
Car: 88 Iroc-Z
Engine: 355ci
Transmission: WC-T5
Old Feb 26, 2003 | 10:55 AM
FLYNLOW92rs's Avatar
Well here what mine looks like...
You barely notice after you have modified the 3rd Gen radio pod, and i haven't had any troubles with it......
I also cut that little piece that extends, with what looks like a bolt hole???, I just cut it off and sanded it to look smooth.....
Hope this helps, but the console gets "pushed" down by the 3rd gen radio pod and holds in place.....
Old Feb 26, 2003 | 01:05 PM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
Have u played witht he mounting bolts in the rear? yours does look a little high wootah, maybe its caught on a wire or what not in the back not causign it be seated correctly.
Mine lays flush:
Old Feb 26, 2003 | 08:53 PM
Stell1579's Avatar
Off topic but had to... CustomX that has to be one of the best thirdgen interiors i ever seen ! Whas it hard and what did you need to do the dash?
-Stell
Old Feb 26, 2003 | 11:30 PM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
should i use a 98 up or 93-97 console. i have a 5 spd t tops and a kenwood kdc519 deck thanks
Frozer!!!
Jan 19, 2024 04:55 PM
Casey Meyers
Mar 2, 2016 10:46 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
redmaroz
Aug 16, 2015 11:40 PM
TheJoeY88
Aug 13, 2015 06:51 PM
