hatch leak
Old Mar 9, 2003 | 01:29 AM
hotrod87camaro's Avatar
Car: 1987 Camaro Sport Coupe LT
Engine: 357
Transmission: turbo 350
Axle/Gears: 10 bolt posi, 3.73 gears
hatch leak
i have an '87 camaro and whenever it rains or when i wash it, the hatch always fills up with water, i drilled a hole to let the water out, but it didn't fix it, does anyone else have the same problem, or know how to fix it?
Old Mar 10, 2003 | 10:21 PM
Engine: 357
guess not
Old Mar 10, 2003 | 10:49 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
The best way to find where the leak is comming from is to take out all the rear int pieces, then get inside the hatch and have someone hose down the rear hatch from the outside. You should be able to tell where the water comes infrom. I bet you have a rotted out deck lid to rear glass seal. Or there are these plastic things on the rear hatch, if the glue goes out on them water and lots of it can get up and in thru them. I'll attach a pic of that. Its a crappy pic but gives you the location of what I'm talkin about.
Old Mar 10, 2003 | 10:52 PM
Engine: 357
thanks i will try to look at it again the next day it isn't way too cold outside and see if i can figure it out and fix it.
Old Mar 10, 2003 | 10:55 PM
Car: 85 Camaro SC
Engine: V6
Good luck, leaks are a pita to find and fix. The little plastic piece I attached was letting in tons of water into my hatch. If your are able to pull it up from the decklid then I'd take it off and put tons of weatherstripping adheasive or silicone on it. I used weatherstripping adheasive on mine.
Old Mar 11, 2003 | 09:53 PM
Engine: 357
yep, it was getting a whole bunch of water in there, one time it had like 3 inches in the bottom, but it looks like there is a plastic thing like that on both sides, and there are watermarks right there in the carpet, so i am pretty sure that's what it is but i haven't got around to fixing it yet, but thanks a lot!
Old Mar 23, 2003 | 05:46 PM
CaysE's Avatar
how exactly do you "fix" those two plastic rectangles from leaking? that's where mine is leaking
PurelyPMD
May 5, 2016 04:57 PM
punkmaster98
Sep 30, 2015 11:01 AM
IROCZDAVE (88-L98)
Sep 22, 2015 02:22 PM
bubbaz28
Sep 18, 2015 02:09 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
