Test Fit 4th Gen T/A Wing: HELP!
Old Mar 16, 2003 | 06:48 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
I bought my fiberglass 4th gen repro wing from the TGO classifieds. It's new, but I didn't get the hardware or installation instructions. After test-fitting to the car today, I see that the long clips on the side of the hatch glass frame (for the old GTA style wing) seem totally wrong for the new wing. I thought the new wing was supposed to use the factory clips.
Anyway- I'm attaching a pic of the existing clip and a couple of the wing. Can someone who has put this wing on their car please tell me how the arms that extend forward are supposed to be installed?
Attached Thumbnails Test Fit 4th Gen T/A Wing:   HELP!-newwing1.jpg
GarageToys's Avatar
Here's one of the existing hatch clips
Attached Thumbnails Test Fit 4th Gen T/A Wing:   HELP!-hatchclip1.jpg
Old Mar 16, 2003 | 06:49 PM
GarageToys's Avatar
Here's what the wing mounting point looks like:
Attached Thumbnails Test Fit 4th Gen T/A Wing:   HELP!-wingmount1.jpg
Old Mar 16, 2003 | 06:50 PM
GarageToys's Avatar
A more comprehensive view showing that there's only one mounting point per side--- but the GTA spoiler had 3. HELP
Attached Thumbnails Test Fit 4th Gen T/A Wing:   HELP!-wingmount2.jpg
Old Mar 17, 2003 | 05:48 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
It looks like a pin is supposed to screw into the spoiler and slide into the slot on the hatch clips.
How firm are the arms on that wing?
When I had my 91-92 T/A Spoiler mounted on my 86, I didn't hook up anything on the arms since I had no provision on the hatch. Used the 4 hatch bolts and I was good to go. I just put some stick on foam to keep the arms from rattling on the glass.
Old Mar 17, 2003 | 06:29 AM
GarageToys's Avatar
That's what I originally thought too, but the mounting point on the spoiler is between the 1st and 2nd clip on the hatch. Those clips are spot-welded on so I can't relocate them.
I know the hatch was lined up correctly because the bottom of it has a "notch" where it goes from the glass to the decklid. Also, the existing hatch clips were covered up by the GTA spoiler (the old wing fit over them). If somehow this spoiler was supposed to screw to the clips it would make the spoiler stick 1/2" off of the glass & you'd see the clips.
Old Mar 17, 2003 | 06:35 AM
Zepher's Avatar
Oh, ok, I see what you are saying.
Mount the spoiler to the deck lid and see how sturdy the arms are. Might not even have to clip the the arms to the hatch.
This is my 91-92 wing on my 86.
(edited to keep on topic)
Old Mar 17, 2003 | 12:48 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The 4th gen spoiler doesn't use the GTA wing hardware. Only the stock GTA-style wing uses that stuff.
The 4 posts in the back just use bolts of whatever size. The tabs on the front of the spoiler are J-shaped that screw to the spoiler and wrap around the edge of the window. It's a half-assed setup, but after you bend and tweak them, they stay. I'm sure that whoever it is that bought out/replaced GTAuto can sell you a hardware kit.
Old Mar 17, 2003 | 10:33 PM
firebirdpl's Avatar
Car: 89 Formula
Engine: 305 TBI
forget the spoiler nice girl zepher
Old Mar 20, 2003 | 07:39 PM
Gambit69's Avatar
Car: 1989 Pontiac Firebird Formula 350
I am getting ready to order my 4th gen spoiler and i am just wondering how you got your old one off. I havent really looked at mine yet but i was just wanting some info from someone that has already take off the wrap around spoiler and put on the new 4th gen spoiler. Any and all help is very apreciated.
Old Mar 20, 2003 | 09:23 PM
GarageToys's Avatar
Piece of cake. Open the hatch, pop out the rubber plugs that cover the bolts and take out the 2 bolts that hold the rear part of the spoiler and the 2 that hold the 3rd brakelight on 87-up cars. Then lift up a little on the spoiler and push forward to release it from the clips on the side.
Anyone else have a 4th gen wing with tips on mounting it?
Old Mar 20, 2003 | 11:16 PM
Spdfrk1990's Avatar
im sure 4th gen and 3rd gen spoilers mount alot different
Old Mar 22, 2003 | 10:57 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
Nice car Gambit69. I was also thinking about the 4th gen style wing for my Kitt, but I decided to put that idea on hold till after the LT1. Let me know how it all works out, hopefully the wing problem will be an easy fix.
Old Mar 29, 2003 | 07:46 PM
GarageToys's Avatar
Got it mounted
Originally posted by Jim85IROC
The 4th gen spoiler doesn't use the GTA wing hardware. Only the stock GTA-style wing uses that stuff. The 4 posts in the back just use bolts... The tabs on the front of the spoiler are J-shaped that screw to the spoiler and wrap around the edge of the window...
Yep, exactly right. Thanks Jim. I found the tabs in the bottom of the box the spoiler came in. However, it still won't fit on cars with wrap-around spoilers... until you drill all the welds off the 6 clips on the hatch glass frame and remove them. As soon as I did that, it fit perfectly.
Attached Thumbnails Test Fit 4th Gen T/A Wing:   HELP!-testfitnewwing.jpg
Old Mar 29, 2003 | 07:47 PM
GarageToys's Avatar
Here's the clips you have to remove
Attached Thumbnails Test Fit 4th Gen T/A Wing:   HELP!-hatchclips.jpg
Old Mar 29, 2003 | 07:48 PM
GarageToys's Avatar
... and here's a diagram (thanks Paint!) of the changes.
Attached Thumbnails Test Fit 4th Gen T/A Wing:   HELP!-testfit2.jpg
Frozer!!!
Jan 19, 2024 04:55 PM
cam-mike
Aug 24, 2015 07:23 AM
