Underbody
Old Apr 17, 2003 | 07:18 PM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
Underbody
Im looking at this camaro, how where shoudl i look to see if its rotted or rusted bad? dont use many fancy terms because im not super car smart or anything so i :hail: to those of you who are. thx - greg
Old Apr 17, 2003 | 07:28 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
check all of each fender. paintjob can cover up rust pretty good visually but underneath it can be very bad. look for bubbling or loose feeling metal. tap all around the fenders, if it sounds dead or like its gonna break it has rust. also check the floorpans.
Old Apr 17, 2003 | 07:42 PM
Engine: 400
alright, yeah it is my uncles but i will check into it myself, i can get it for free, the paintjob is good, but there are spots where it is chipped paint and whatnot, but my main worry is underneath.. and if thats ok the biggest thing is the engine and other stuff. thanks for the help.
-Greg
Old Apr 17, 2003 | 09:28 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
It's free. Take it. What are you looking at rust for? Are you going to tell your uncle that it's not nice enough and he should give you a better car?
But to answer your question- check the floorpans, the rear wheelwell lips, open the hatch and look at the bottom of the hatch for rust. Also look under the spare tire.
Old Apr 17, 2003 | 09:53 PM
Dirty Rob's Avatar
Check the strut towers too.
Old Apr 18, 2003 | 01:54 PM
Engine: 400
whats a strut tower?
Old Apr 18, 2003 | 05:49 PM
Dirty Rob's Avatar
When you look under the hood, on both the right and the left, the top of the struts are mounted there, covered by plastic caps. It likes to rust underneath the plates. Sorry i couldnt get a picture and explain better, but i am literally falling asleep at the keyboard.
Old Apr 18, 2003 | 06:09 PM
VampireHunterC's Avatar
Even though it is free, he probably wants to be able to determine if it is worth putting any money into. I got my Camaro for free, and I had my dad look it over to make sure that there was no massive body damage that would make it unsalvageable.
Old Apr 20, 2003 | 02:46 AM
Rage13's Avatar
Car: 89 Firebird
open the doors and look at the under side of them, and if your under the hood check out under the a/c fan box, its one the passenger side all the way to the left aginst the firewall. leaves and other stuff collect under there and help the rust... i've got a hole big enough to put my fist thru on my camaro
armybyrd
Oct 24, 2015 06:59 AM
TheExaminer
Sep 28, 2015 02:28 PM
Hg
Aug 9, 2003 10:57 PM
rubbermanZ28
Jun 27, 2003 12:42 PM
Buck268
May 25, 2002 08:58 PM
