Fenders
Old Apr 23, 2003 | 05:35 PM
txhotRS's Avatar
Fenders
Can anyone tell me what sort of time it takes and the difficulty of replacing a passenger side fender w/ GFX (I have both new parts) on an '89 camaro, some dumb azz apparently backed into it while I was IN the mall , I'm going to get a new paint job during the summer ANYWAYS so, that part doesn't bug me, how hard is this job... thanks guys
Old Apr 23, 2003 | 08:47 PM
SpeedCat86's Avatar
Car: '86 TransAm WS6
Transmission: Custom TH700R4
I don't know, but I will as soon as finals are over. Doesn't look too bad. the hardest part looks to be unhooking the nose (from inside) from the sheet metal. Get a buddy, 'cause you gotta take the hood off (the hinges bolt to the fender)
Old Apr 24, 2003 | 09:18 AM
Irhal's Avatar
Car: 94 Firebird
Engine: 3.4L
Transmission: t5
is the other fender really screwed? my advice would be not to bolt on the new fender and wait for you to go get a new paint.. driving with the new one will just damage it and make it harder to prep the fender... and without proper paint it might even start to rust... rust doesn'T take long to eat sheetmetal!! beware...
Old Apr 24, 2003 | 10:28 AM
Andy Fanshawe's Avatar
Car: 91 camaro rs
You don't need to remove the hood unless you want to. Just support the front of it with a clothes prop, perhaps, and then undo the bolts holding the hinge to the fender. The hinge will then try to tip forward and inwards, where it can be pushed out of the way.
The nose cone will need pulling forwards a bit to clear the bolts there.
I also tied a rope between the door mirror and the hinge just in case-but didn't really need to.
Andy.
Old Apr 24, 2003 | 10:59 AM
txhotRS's Avatar
what about the door hinges ??? and yes ... the old fender IS SCREWED... it's pretty bad.... I was planning on replacing it the DAY OF or NIGHT BEFORE I take it in to get it painted, will that screw it up. I'm afraid I don't understand why I would damage it..
Old Apr 24, 2003 | 11:09 AM
SpeedCat86's Avatar
If you look at the picture, I believe he's talking about tying a line from the wing mirror to the hood hinge, to keep the hood in position. The door hinges have nothing to do with it.
Old Apr 24, 2003 | 07:25 PM
Irhal's Avatar
Car: 94 Firebird
Engine: 3.4L
Transmission: t5
you probably wouldn't damage it... but pebbles on the ground would knock on the cheap primer covering the sheet metal.. and in less than a week you would have rust on it... the same goes with dirt gather in the fender well would be a PITA to clean after... but if you have no choice.. you gotta do what you have to
morrow
Jan 13, 2024 12:29 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
jovibuilt
Oct 18, 2015 08:12 PM
kkirch15
Interior Parts Wanted
Oct 15, 2015 02:21 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
