When did the dashes change in birds?
Old Apr 25, 2003 | 09:08 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Hey, I'd like to get another dash for my 82. I was wondering what years came with that dash.
Old Apr 26, 2003 | 12:41 AM
Chet's Avatar
Car: GTA
IIRC they stayed mechanical until '85. '86 and beyond all had electronic speedos. So you should be able to do a direct swap from the years 82 through 85.
Old Apr 26, 2003 | 01:19 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I think it was 82-84 had the same style dash and console. 85 I think they went to the 2 tone colored dash, black/grey as well as the new center console.
Old Apr 27, 2003 | 12:28 PM
Steve86TA's Avatar
Car: To many to list
82-85 interchange
Old Apr 27, 2003 | 09:18 PM
Firebird355's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
hmm my friends 87 firebird (basemodel) had newer style console, and olderstyle dash, but there were only two gauges big speedo, big gas gauge. the other two just have like blackout plates where the other gauges would be
Old Apr 28, 2003 | 10:16 AM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
What were you needing a dash pad? I think the Firebird dash pad is interchangeable on all years. They look a bit different (contours) The early ones have a edge that has a different design. Has a ridge in the edge... the later style has a smooth rounded edge.
Or were you meaning the actual dash guage cluster panel? The gauge trim panel style changed around 86, I think, to the gray textured panel. Then the 91-92 cars had different lower dash trim.
My base model 87 (2.8) had the gauges with a speedo and gas gauge and the rest were idiot lights (small circles to the right of the 2 main gauges)
On the speedo style, mechanical versus electric...My 87 has a speedo gear, so it is mechanical...again 2.8 L with a 700r4
Jorlain
Aug 24, 2022 05:11 PM
z28_AJ
Aug 27, 2015 08:59 PM
355tpipickup
Aug 19, 2015 10:02 PM
Catcher55
Aug 15, 2015 07:08 PM
Vintageracer
Aug 11, 2015 08:13 PM
