Install Of Triple Pillar?
Old May 1, 2003 | 09:09 AM
Maximus's Avatar
Car: 1992 Camaro Z28
Transmission: 5spd.
HOW DID YOU RUN THE WIRES? DID YOU DRILL HOLES THROUGH THE ORIGINAL PILLAR FOR THE WIRES, OR GO BEHIND THE NEW ONE? ALSO, DID YOU GO THROUGH THE FIREWALL? I HAVE MY TACH WIRES GOING THROUGH THE PASSENGER KICK PANEL UP THROUGH THE WHEEL-WELL. I DON'T KNOW IF I SHOULD RUN THE WIRES FROM THE PILLAR ALL THE WAY TO THE PASSENGER KICK PANEL. ANY SUGGESTIONS?
Old May 1, 2003 | 06:14 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I have a dual-pillar, with mechanical gauges, but here's an answer anyway-
I drilled through the firewall. If you haven't drilled yet, there might be a plug in the firewall by the brake booster that you can knock out with a hammer & punch.
The tubing and the wires for the gauge lights come up behind the dash, and go up the pillar.
Old May 2, 2003 | 02:18 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I drilled through the stock a-pillar. I didn't mind since my car won't be sold (and if it is, then the new owner gets holes in the a-pillar) and I really like my triple pod.
Old May 2, 2003 | 08:04 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I'm running the gauge hook-ups thru the stock pillar cover. In my case, it's the only way to go.
Old May 2, 2003 | 12:47 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Oh, duh, forgot that bit of the question; yes, I also drilled a hole thru the stock a-pillar. 'Course, I have a spare in the basement from my parts car; kept it in case I messed up the gauge pod. I also screwed my pod to the a-pillar instead of using double-sided tape. One day in the sun with that tape and my gauge pod was hanging off the pillar! I painted the screws with primer, then gloss black.
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
Camarothatcould
Aug 20, 2015 08:49 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
