Fender Removal Question
Old May 4, 2003 | 03:28 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Removing the passanger side fender here... I've got all the bolts out, but I'm not sure how the radio antenna wire comes off the fender! I see it running up the brace... how do I remove the wire to get the fender out?
Old May 4, 2003 | 05:05 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
At the base of the antenna mast, you'll see a round piece with 4 notches (image below). This unscrews (after the antenna is off obviously), the plastic piece under it comes off and the fender can then be lifted off the antenna base.
Old May 5, 2003 | 12:35 AM
SydwayzTA 86's Avatar
Car: 1986 Trans Am
Engine: 5.7L TPI
yeah thats exactly right, just get like maybe some pliers and turn it off, or get a screwdriver and a rubber hammer and tap it, which ever works best for you
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
3rdgenparts
Aug 8, 2015 07:09 PM
