pin w/ roller in lower hinge
Old May 10, 2003 | 11:09 AM
demonchild's Avatar
i finally go tthe doors off and am going to be replacing the top hinge bushings with a kit from top sown solutions that is manufactured by 3rdgensolutions. one of my friends had a new kit sitting around for the bottom hinges that included 4 bushings and 2 pins. anyway where do i find the pin that is machined into the hinge. the one witht the roller on it? and how do i replace that piece?
Old May 10, 2003 | 12:09 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I don't know if its the same as most other cars, but there are actually three parts there. there is a "hinge stop" which is the long pin that goes through the hinge, then there is the roller, and there is a small pin, that goes through the roller and into the hinge stop. I know you can buy all three seperatly. I had an '02 Jimmy with a popping noise when you opened the door from a bad roller and I had to smack the hell out of it to get the little roller pin out of the hinge stop.
Old May 10, 2003 | 11:57 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
You may find it easier to replace the lower door hinge "body side" hinge strap. It is available as GM# 20314681 (drivers side). It comes with a new roller and new bushings already installed.
Thanx, andyZ28
Hotrodboba400
Dec 10, 2019 07:07 PM
Veaceonee
Sep 29, 2016 08:15 PM
BHR
Sep 3, 2015 07:51 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
gixxer92
Sep 1, 2015 04:32 PM
