Rear wing removal/repair
Car: 87 T/A
Engine: LM1 350
Transmission: 700 R4
Anybody have experiance in removing the rear wing ??? Need help on the proper way to do this and tools needed. How is it attached to the body and how hard is it to remove and out back on. Thanks in advance.
Car: 1992 Firebird
Engine: 3.1 V6
The 91/92 aero wing is held to the hatch by four bolts and some little clips on the glass trim. I think I first had to remove the black cover to get to the bolts, then remove the bolts, pull the hatch back and it came off.
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
In 87 ther was 4 bolts under the rear metal panel. You will have to pop off the plastic trim pieces, and there are TWO that hold on the high mount Cyclops light.
The service manual says to push it forward or pull it back I forget...
There are 6 plastic tabs that push up into the spoiler in the spears. Be careful with these, have somene help is my suggestion.
Good luck.
John
Good luck.
John
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
