Sticky Power Locks
Old Jun 14, 2003 | 08:38 PM
helloriker's Avatar
Sticky Power Locks
Ok I took off the door pannel on the passenger side of my GF 91 RS and after putting it back together the power door lock doesn't work. The motor works but it seems like the mechanism is binding up somewhere. Anyone have any ideas where and how to fix it? Thanks
Old Jun 16, 2003 | 12:25 PM
90_formula_305's Avatar
Door Locks
I have a 90 Formula and my driver side door lock hangs up too. I am wondering how you got the door pannel off. Ive tried several times but can'nt seem to get it. My buddy told me to lube the arm that connects too the lock, but I don'n think it can be done right without removing the door pannel.
Old Jun 16, 2003 | 12:29 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Look in Haynes or Chilton's manual on 82-92 Camaro's/Firebird's.
Find section on door panels install/removal. Once you have the door panels off, grease the rods where they clip on and make sure the grounding strap for the power locks relay has a good ground. (This relay is located behind the driver side lower kick panel). This will fix the problem.
BRoss99
Aug 10, 2025 05:08 PM
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
mantaguy
Sep 1, 2015 08:39 PM
sailtexas186548
Aug 24, 2015 10:11 PM
zayne0
Aug 24, 2015 07:22 PM
