Speedo, cluster swap...
Old Jun 20, 2003 | 11:14 PM
PioneerCrazed's Avatar
Car: Mark VIII
Engine: 4.6L DOHC
Transmission: 4r70w
Is it possible for this cluster to bolt right into my existing dash of an 86 z-28 w/ a 85 mph speedo.... http://cgi.ebay.com/ebaymotors/ws/eB...tem=2420185620
Old Jun 20, 2003 | 11:35 PM
jgifford's Avatar
Car: 1986 Z28
Engine: 355TPI 380hp
Transmission: Rebuilt 700r w/ Transgo Shift Kit
It's a direct swap, I just did mine a couple of months ago.
Old Jun 21, 2003 | 12:10 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Be careful, you might run into a couple problems. Does your current gauge cluster have gauges for the oil pressure and temperature, or just warning lights? If you have warning lights, you'll need to switch sending units for the oil pressure and temperature. If so, don't fret, its not very hard, and both sensors can be had for under $30. On the other hand, if you already have gauges for the oil pressure and temp, then you're good to go, it will swap right in.
Old Jun 21, 2003 | 09:03 AM
Car: Mark VIII
Engine: 4.6L DOHC
Transmission: 4r70w
Thanks for the replies...
I already have an oil press. gauge and a temp gauge in my cluster, everything is basically the same accept for the speedo.
BUT my oil gauge is quite useless, it just bounces around; and the water temp gauge is not accurate either.
What would it take to fix that, or could the new cluster help?
Old Jun 22, 2003 | 12:12 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Well, it could be a few things. What do you mean your oil pressure gauge bounces around? And how do you know your water temp gauge is not accurate?
Old Jun 22, 2003 | 12:27 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Speedo, cluster swap...
I dont know if you noticed ,but the speedo needle is orange not white.Its probably from the half 85mph/kilo speedo w/the double needles.You can see where the other piece broke off.
Old Jun 22, 2003 | 01:02 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
If it matters to you the 145 speedo is aslo not of the 84 & prior years.I think they are the later iroc styleheres a pic of my original 84z28 gauges.currently Ive got digital gauges installed(nordskog)
Old Jun 22, 2003 | 07:37 AM
Car: Mark VIII
Engine: 4.6L DOHC
Transmission: 4r70w
The oil press. in the cluster doesn't read, and acts like it has a super spring in it by going from 0 to straight up passed 60, or flipping all the way over.
I know that the temp. gauge doesn't work because it stays on the 100* mark nearly all the time, and I have a dual A-pillar pod with both a mechanical oil press. gauge ran through with copper, and a mechanical temp. gauge.
I noticed that orange needle but just figure i could swap out one from my old cluster, and I thought the one in the pic was from only years 86-89, not '84, but if I get whats in the picture that would work.
Old Jun 22, 2003 | 07:40 AM
Car: Mark VIII
Engine: 4.6L DOHC
Transmission: 4r70w
I just noticed the cluster on ebay looks like yours from 84, like the rest of the needles which are continually "pointy", and the yellow and redline on the tach are just like yours, only little marks, mine is like a full line.
Wonder if it was swapped or something, I'm thinkin about passing up this one.
Old Jun 22, 2003 | 05:43 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
The tapered needles with the verticle seperate lines are the first design.the needles with the tips cut down are the later style as are the full lines for the red zones.Ive never seen the tapered needles with the full red lines.Unless someone switched the needles.scroll down for pic of both.bottom is later style,top is first design
Old Jun 22, 2003 | 05:58 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
bottom 1 is from an 88.top is from my 84
Old Jun 22, 2003 | 06:06 PM
Car: Mark VIII
Engine: 4.6L DOHC
Transmission: 4r70w
What are you doing with that 88?
Old Jun 22, 2003 | 06:13 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Im going to put it on ebay.I was going to this morning with some slp headers,edelbrock muffler,flowmaster dual cat force 2 exaust & other f-body stuff,but i didnt get a chance.maybe monday now.
Old Jun 22, 2003 | 06:32 PM
Car: Mark VIII
Engine: 4.6L DOHC
Transmission: 4r70w
nevermind
Old Jun 22, 2003 | 06:37 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
I dont know the current rate for LT1s,but that sound good to me.I would at least like to hear it run or some kind of assurance that everthing works.
bigjay89gta
Oct 15, 2015 08:04 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
