What years for molded firebird doors?
Old Jun 30, 2003 | 06:54 PM
Dustin Mustangs's Avatar
Car: I
Engine: Taunt
Transmission: Mustangs
Hey, 3 quick questions:
1.) What year firebirds came with the molded door panels from the factory?
By molded I mean the ones that aren't as flat as a board and that are made out of that thin tag board material.
2.)Also, do they require a special inside handle and trim bezzel other than the ones that are found on flat door panel f-bodies?
3.)Does anyone have a pic of one of these?
See the attached pic for an example of what I refered to as a flat door panel, which also has what I refered to as a trim bezzel marked with green.
Thanks a bunch for any info!
:hail:
Old Jul 1, 2003 | 10:02 PM
Tonyrodz's Avatar
Transmission: auto
These? They were stock on the GTA's--87 through 90 I think? Also were an option on Formulas.
Attached Thumbnails What years for molded firebird doors?-gta-door-panel-pass
Old Jul 1, 2003 | 11:27 PM
charlie31603's Avatar
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
Those are sweat will the work in a camaro?
Old Jul 1, 2003 | 11:48 PM
zer0321's Avatar
yeah, they are sweet!
They bolt right into a camaro if you get the entire door panel (door handle cutout and armrest included)
the only problem you will run into is the armrest bracket will need to be changed, with a different one...and they are rivited on, so you have to drill them out and bolt the new one on.
Old Jul 2, 2003 | 10:27 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Actually they were optional on all Firebirds Base, Formula, T/A to GTA... They came with the "Deluxe" Interior, and also with the "Ultima seats" commonly called GTA seats were another level up.
I KNOW for sure that they were availble in 87-89, in 1990 they changed them to all the same design used thru 92. 86 they were NOT availble. And they are far and few between. I have only seen 2 sets in junkyards.
To install them you need the Armrest bracket, and the Door handle for the screw that holds the plastic trim piece...
hope that helps.
Old Jul 2, 2003 | 03:13 PM
Tonyrodz's Avatar
Transmission: auto
I installed these on my 86 T/A--instead of replacing the metal bracket for the armrests, all I did was drill another hole and use a longer screw from another set of door handles. Easy as hell!!
Old Jul 2, 2003 | 05:50 PM
Diggler86's Avatar
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
i installed them too.
i found that i did need the arm bracket off the donor car. its a PITA drilling out the rivits for everything but other than that its not bad.
Old Jul 2, 2003 | 06:07 PM
Car: I
Engine: Taunt
Thanks tons fellas, that's exactly the info I was looking for. Now all that's left is to find a tan pair for sale!
Old Jul 3, 2003 | 09:15 AM
mat89RS's Avatar
Fore sure it fits into a camaro. here's a look of mine
Old Jul 3, 2003 | 12:20 PM
Tonyrodz's Avatar
Transmission: auto
for the roll up windows-did you have to drill the holes for the *****? I've never seen a car w/these door panels that had roll ups!!
Old Jul 3, 2003 | 01:10 PM
mat89RS's Avatar
Yes, I had to drill holes, if you look, you will see that I damaged the fabric by mistake. You have to be carefull when you do that.
Old Jul 3, 2003 | 01:33 PM
okfoz's Avatar
The door panels were available with crank windows from the factory...
John
Old Jul 4, 2003 | 07:51 PM
85maroz28's Avatar
Car: 1985 Camaro Z28/1989 Pontiac Trans Am GTA
Engine: 305 tpi/350tpi
I know of an 86 w/ these door panels. But.. up top its says it was not avalible in 86?
Old Jul 5, 2003 | 09:58 AM
okfoz's Avatar
They do not show in for 1986 in the Parts & Illustration manual. It is entirely possible that it was a late 86 that got some 87 options... dispite common belifes, things do happen that way, late 86's getting 87 setups, and early 87's getting left over 86 parts for example.
John
Old Jul 5, 2003 | 11:08 PM
85maroz28's Avatar
OK that makes sense. Thanks
Old Jul 6, 2003 | 04:05 AM
Spdfrk1990's Avatar
i wanted them door panels ever since i seen them on my buddys gta when i first got my car his interior looked so much better. He had the all black cloth interior with the over head console and all. I always liked t/a's console better also, he sold that car and i wanted to buy it. black/black 87 305 5-speed ugh that thing hauled for a 305. 1 more thing do they have the spot for the manual side mirror on the driver side door panel cause i think his car had electric mirrors.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
BlackTopKing
Aug 19, 2015 12:13 PM
sonu1975
Aug 11, 2015 08:38 AM
