Side Mirror Rattles!!!
Old Jul 26, 2003 | 09:03 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
The topic says it all my driver side mirror rattles very bad probly from my subs i have tightend the screws inthe back well just 1 because thats the only one i can get to and it helped some but im sure the other ones that are hideing back there need to be tightend. How can i do this with out makeing it into a day long project or brakeing my mirror. It is a power mirror BTW
Old Jul 26, 2003 | 09:31 PM
Tyler-88's Avatar
the way i tightened my pass side mirror was to just angle the mirror away from the screw i was trying to get at. it was tight to get a screw driver in there, but i did it :>
Old Jul 26, 2003 | 10:43 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
My car always rattles them lose where it bolts to the door, I have to pull the door panel, roll down the window, and just go in with a open end wrench from the top, But to keep from doing this use some loc tite, blue should be strong enough. no more lose mirrors.
Old Jul 27, 2003 | 09:50 PM
MikeC.86Roc's Avatar
There are three mounts with phillips head screws. You'll never get to the one on the bottom unless you can unsnap the mirror from its mount on the power pivot assembly. I can get you some digital photos if you really need them...
Old Jul 27, 2003 | 11:30 PM
88blackbird's Avatar
Car: 88 Trans Am GTA
I have the same prob with my 88 GTA!! So it is just the mount screws coming loose? cool easy fix..:hail:
Old Jul 27, 2003 | 11:48 PM
FAST RS's Avatar
how do i unsnap the mirrot??? its not the houseing its the mirror it self. Could you send me some pics please.
Old Jul 27, 2003 | 11:50 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
There are several things that can cause the mirrors to rattle.
1) As already mentioned, there is a cast pot-metal bracket that attaches the motor to the housing. This could be loose if the screws are loose. Or that cast bracket could be broken. In that case you'd have to replace it.
2) On later-style electric mirrors there is a cross-shaped piece that attaches the back of the mirror to the motor. Sometimes that piece comes free and needs to be popped back into the molded plastic mirror backing. If you have this style you can cover the mirror with a towel and carefully press it back onto the cross-shaped piece.
3) Early-style mirrors had a screw holding the plastic mirror backing piece to the motor. To replace the mirror on these you have to break the glass to get to the screw. Large auto parts chains sell replacement mirrors for a lot less than the dealer. I've found the "Objects in the mirror..." etched on the passenger side mirrors was a bit fuzzier than a new GM piece though.
4) The motor screws to that pot-metal bracket. Sometimes those screws can vibrate loose.
I forgot to mention to use safety glasses, hammer and gloves if you have to break that mirror to get to the screw.
Good luck, Lon
Old Jul 28, 2003 | 09:33 PM
1988-1992 Z 28's Avatar
Car: 1987 Firebird
Engine: 350 not original
Transmission: automatic
loose mirror
I just noticed today that the passenger side housing on my 90 is loose. Does it tighten from inside the door or out side under the mirror? Thanks
Old Jul 28, 2003 | 09:38 PM
FAST RS's Avatar
The houseing on mine isnt loose its the mirror it self. So i wul dhave to brake the glass and replace it to tighten it??? Also how many peoples driver side rearview say objects in mirror are closer then they appear mine does not say that at all mirror.
Old Jul 28, 2003 | 10:03 PM
Ok, I got some pictures, but I can't post them here because the file size is just a little too large for them to be allowed.
I can email anybody who wants them though.
Old Jul 28, 2003 | 10:05 PM
lonsal's Avatar
What year is your RS? You can power the mirror to the extreme lower position and look in from the top to see if there is a cross piece in there. Assuming the part it snaps into on the back of the plastic mirror backing hasn't broken, then you can carefully just pop it back into place. The motor switched in either 88 or 89.
Lon
Old Jul 29, 2003 | 03:52 AM
FAST RS's Avatar
its a 91. I think there is some kind of metel clip in there im not 100 percent sure.
Old Jul 29, 2003 | 03:53 AM
FAST RS's Avatar
Can you email them to me Luniz2003@aol.com Thanks
Old Jul 29, 2003 | 07:29 PM
icebird_1981's Avatar
i had the same problem, i used a thicker screw not nuts just a screw and just screwed it up in there. now that thing will not budge.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
