door panels
Old Jul 28, 2003 | 04:32 PM
demonchild's Avatar
door panels
what is the cardboard like material that the door panels are made out of? basically the backboard that the cloth materials are set to.
TIA
Old Jul 28, 2003 | 10:16 PM
MikeC.86Roc's Avatar
Good question. Wish somebody could answer it or tell us where to get it!
Old Jul 28, 2003 | 10:55 PM
demonchild's Avatar
ttt.
i hope someone can answer this. i want to get started soon. i looked at lowes and home depot, but didnt see anything that resembled the material used. it looks like a heavy duty cardboard.
any help is appreciated.
Old Jul 28, 2003 | 11:16 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
I wouldn't bother. I would just get the aftermarket door panels which are made of plastic instead of cardboard. In fact, that's what I did. I am waiting on them to arrive.
Old Jul 28, 2003 | 11:47 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
can you get just the plastic w/o the covering on them?
Old Jul 29, 2003 | 12:34 AM
fast83camaro's Avatar
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
If they did, they would be a good start for some custom door panels....
I can see it now......:hail:
Old Jul 29, 2003 | 12:46 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
that was my plan ....
Old Jul 29, 2003 | 02:04 AM
87WS6's Avatar
Ahh. I didn't understand that you wanted to do custom door panels. I wonder if you could take the material off the backing and do that. If not you might be able to find a substitute out of something else.
Old Jul 29, 2003 | 11:25 AM
demonchild's Avatar
plastic...
who has the plastic backings???
Old Jul 29, 2003 | 09:41 PM
89rsragtop's Avatar
Car: blue
Transmission: 6 speed
Axle/Gears: 3.73 posi
87WS6,
If you ordered the hawks door panels they are not plastic. They are cardboard and thinner than the factory ones.
Old Jul 30, 2003 | 01:19 AM
demonchild's Avatar
havent yet, so who has the plastic backings?
Old Jul 30, 2003 | 02:31 AM
SC82TA's Avatar
Car: 1982 Pontiac Trans Am
Engine: Stock carbed 305
Transmission: Stock 200C
I know someone that just took their old cardboard door panel as a template and then took some thin pelxiglass from home depot and cut that out. Then he recovered it with material.
Old Jul 30, 2003 | 09:35 AM
JR86-TA's Avatar
Car: '86 Trans Am
I know that at Hobby Lobby, they have this thick cardboard stuff just like what the door panels are made out of... The only problem is, you will need two peices to make it the right size. Just staple them together... By the way, here it is 5 bucks for one sheet of the stuff.
Old Jul 30, 2003 | 11:39 AM
demonchild's Avatar
dosent plexiglass break easy. im 16 and my firends are ruthless with my car...wouldnt one knee to the door panel break it?
Old Jul 30, 2003 | 12:41 PM
SC82TA's Avatar
Plexiglass is pretty flexible and its gonna be attatched to your door...I'm pretty sure its resilient enough to take a knee. Go to home depot and play around with it yourself see how flexible it is.....I believe Lexan is even stronger and they sell that there too. Besides I mean I believe your friends might hit it with their knee going ot the car or something, but how much force are they gonna use? I sill think that if you purposfully open the door and kneed it the plexiglass would still not break.
Old Jul 31, 2003 | 01:57 PM
demonchild's Avatar
sounds good...ill try it a home depot. thx for the replys.
Old Aug 1, 2003 | 08:20 PM
joezero's Avatar
Car: See pic above
Engine: Too Small
Transmission: Broken
It may be hardboard, which is should be avaliable at places like home depot. If you're wanting custom ones, there are other options. Mine are from www.roddoors.com They're made out of molded ABS and then you cut them to fit. I really like them, and was glad to be able to get rid of the factory arm rest. I talked to someone selling custom door panels on ebay and they said that the manufacturer wouldn't sell them uncovered, so I looked elsewhere.
www.geocities.com/jcargile2001/doorpanel.html
Old Aug 1, 2003 | 09:03 PM
TROOPER's Avatar
Car: 89 formula
Engine: yup its in there
Transmission: no ,i had my shots
what i used for mine was paneling you know that white shiney stuff they use in kitchen and bathrooms laid what was left of my old one traced it out and cut it with a saber saw drilled the holes with a step drill bit and used a small rasp to file any slots thwn sanded all the rough edges with 80 grit paper about 15.00 for a 4 x 8 sheet and 3 hours work for two panels
Old Aug 1, 2003 | 11:36 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
did a search for plastic sheets on google found this site it might work
http://www.usplastic.com/catalog/pro...e+1+Full+Sheet
http://www.ridoutplastics.com/blackabssheets.html
Old Aug 2, 2003 | 10:42 AM
demonchild's Avatar
actually i dont...please expand. thx.
thx for the links aviator
Old Aug 2, 2003 | 03:06 PM
azcamaro's Avatar
Car: 1987 IROC-Z / 1992 Corvette
Engine: 305 TPI / LT1
I wonder if wood paneling would work?
Old Aug 2, 2003 | 11:44 PM
TROOPER's Avatar
Car: 89 formula
yes its wood panneling but real smooth and shinny on one side comes in 4x8 sheets used on kithen and bath walls look around at lowes, or a home depo used it cause i thought it wold hold up better than regular panneling
Hotrodboba400
Dec 10, 2019 07:07 PM
RyanJB
May 7, 2016 06:23 PM
tglennon11
Sep 23, 2015 05:30 PM
NiG
Sep 7, 2015 11:25 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
