New reverse Indiglow gauges installed!!
Old Aug 3, 2003 | 01:49 PM
TransAmTBI's Avatar
Engine: 305 TBI
Transmission: th700R4
wELL THEY WENT IN PRETTY EASALY AND THE LOOK SWEET AS HELL. my speedo is still kinda off i think its 5 mph too low. I'll have to find one of those radar things on the side of the road and drive by it several times.
Anyone got good tips to set my guages right? every other one is pretty good i think my rpms may be like 100 off but not too much at all. I didnt mark them before i took them off but I know how my car usually runs so i set it to that. Since my gas gauge doesnt work anyway that wasnt too hard and since i have a manual fan switch the temp was easy too since i know my car runs at 150 at idle with the fan on and the car not moving. I'll get pics and a movie very soon! i have the movie i'll upload it tomirrow! let me know what you guys think
I also re painted the needles red as derek said and that came out pretty sweet
Old Aug 5, 2003 | 08:08 PM
TransAmTBI's Avatar
Engine: 305 TBI
the video is in the sig!! anyone know how to make it a link instead of cut and paste??
Old Aug 5, 2003 | 10:57 PM
profiveo's Avatar
Car: 1992 Camaro Z28
Engine: 350 L98
The link says the site is suspended. Let me know when you get it fixed.
Old Aug 6, 2003 | 07:00 AM
TransAmTBI's Avatar
Engine: 305 TBI
try it now i tried the new link thing i just learned and when i clicked it it worked so let me know if you got it thanx for telling me!!!
Old Aug 6, 2003 | 08:19 AM
nolanr0413's Avatar
Car: Trans am
very nice , was it a pita to do or was it just time consuming.
Old Aug 6, 2003 | 12:03 PM
TransAmTBI's Avatar
Engine: 305 TBI
not hard at all time consuming kinda hardest part was needles getting them the right reading!!kinda fun thinking of turning the odometer back and selling it with 10,000 miles on it lol
Old Aug 6, 2003 | 02:33 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
:nono: I would really discourage that... Big ole major fedral offence there.
John
Old Aug 6, 2003 | 03:15 PM
TransAmTBI's Avatar
Engine: 305 TBI
i didnt actually do that i was just thinkin thats all i swear lol
Old Aug 6, 2003 | 09:28 PM
daerom's Avatar
Hey.. I am curious.. I bought some reverse glow gages and I was going to install them after work today but I had some problems... I got mine from SR Motorsports, and when I received them I noticed one of the gages has a few problems with it, but I am going to fix that with an exacto(the hole for the trip reset is in the wrong spot and not all the numbers show on the milage). Anyway, Could you tell me what is the best way to get them on? did you remove the cluster out of the dash? did you take the needles off? I was told to try and slip them on without taking off the needles. Also... how can I find out which wires are the ones going to the headlights, so I can give the gages power? Thanks man.. I was starting to get a little frustrated with it and then I saw this topic.
Dan
Old Aug 7, 2003 | 02:58 PM
TransAmTBI's Avatar
Engine: 305 TBI
ok heres the low down..
take out the cluster! really easy and this way you eleiminate all the hassels with other things getting in the way..
some people can get the faces on without removing the needles but i would suggest taking them off.. the only problem is you really have to make sure you put them back on just at they were.. makr where your tem guage is and gas and such..
after putting everything on put the cluster in and test the guages without putting the clear plastic back on... do you have a maro or bird?
it may be alittle diff3erent but i would even drive around and make sure the gauges are in the right spot b4 putting everything back together.
to fine out which wire to hook up just touch the powerr and ground and use process of elimination. i put them to 2 wires then put my running lights on..this should have your gauges coming on too... thenm put your actual headlights on if the wires wrong the gauges will turn off.. and then shut them off and see if the gauges stays on finually you'll find the right combo.
Old Aug 7, 2003 | 04:00 PM
daerom's Avatar
Ok.. cool. I have an 85 Iroc. The thing is the other day I was trying to take the gage cluster out and I got it loose.. but once I did I noticed something was holding it from behind the speedometer, and it felt like it was a wire of some sort so I didn't pull too hard fearing it would break something... Should I pull it out anyway?
Dan
Old Aug 8, 2003 | 06:22 AM
TransAmTBI's Avatar
Engine: 305 TBI
you may have to reach under the dash behind the steering wheel to unplug your speedo cable on the maros but i'm not really to sure... if you have a bird like me you just pull
Frozer!!!
Jan 19, 2024 04:55 PM
rocn7roc
Sep 21, 2021 02:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Aug 17, 2015 02:00 PM
hokis
Aug 9, 2015 03:57 PM
