Could someone show me what goes here?
Old Aug 9, 2003 | 05:23 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
On the front track of the drivers seat. I have covers on my passenger seat but none on my drivers seat front or rear. I have a set of covers I picked up but I am not sure which go where.
Old Aug 9, 2003 | 05:26 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Is the correct orentation for the covers? A pic of them installed would be great.
Attached Thumbnails Could someone show me what goes here?-seat-track-cover.jpg
Old Aug 9, 2003 | 06:40 PM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
On my 83, the piece on the driver's side, which was electric, ran the whole length of the track. I think what you have is correct, and the correct orientation, but I could be wrong. My were so bad that I just removed them detailed the bracketry and left them off.
Old Aug 9, 2003 | 09:12 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
What is pictured appears to be 4thgen seat rails. The 2 sets I've pulled (one from a bird, other camaro) merely had crappy little rupper caps to hide the nuts only. There was no 'trim' to actually hide the rail ends. I can get a pic for you if needed.
Old Aug 10, 2003 | 01:03 AM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
I just got done putting those back on. BTW fourth gen seats do not use those.
Mine were all messed up. I took them off when I removed the seats to redo the carpet. Then aquired another set from a friend that changed his seats out for fourth gen leather.
I would take pics except I have no camera. Just test fit. They use really short screws. The smallest one goes on the passenger side front right bolt area. You can figure it out. That's what I had to do.
They also will go into place fairly easily. If they don't then your probably doing it wrong. I don't know if this helps.
Old Aug 10, 2003 | 05:35 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
You can't use the standard 3rd gen caps on the 4th gen seat rails.
I had to mod some of the 3rd & 4th caps to cover the fronts by drilling new mounting screw holes and left the rears bare (can't see them anyways).
Old Aug 10, 2003 | 09:55 AM
Tonyrodz's Avatar
Transmission: auto
The above pictured covers came from the standard rails(usually the Camaro rails-non power). Your rail is from a T/A--those use different covers, more like a plastic cover w/a metal insert that screws onto the nut itself.
Attached Thumbnails Could someone show me what goes here?-trim-bolts-front-seats
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
3.8TransAM
Oct 1, 2015 07:47 PM
