Interior Dash Lights Ah!
Old Aug 16, 2003 | 11:17 PM
jdrafke's Avatar
WEll i cant figure out y my darn interior dash lights dont work. Im refering to the lights that light up around the guages and the shifter. The outside lights work when i pull out the *** but the interiordash and shifter dont work. Hoever, when the *** is pulled out and the headlights are on if i tunr the *** all the way to the right nad barely push it in the lights coem on! But as soon as i let go they go off. What is losse and causing this, How can i fix it! Please help
Old Aug 17, 2003 | 11:48 AM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
from the sound of that, it might be your light switch that is giving you the trouble
Old Aug 17, 2003 | 04:29 PM
TJQIROC's Avatar
Car: '16 Camaro SS, '88 IROC
Engine: 6.2 Gen V
Transmission: 6 spd TR6060
Someone just asked the same question in the electronics section. I had the same problem just not as bad and replaced the headlight switch today. Only hard part was the speedometer cable. You may not have one to worry about. Not sure what year changed to electronic.
Old Aug 17, 2003 | 07:03 PM
Tonyrodz's Avatar
Transmission: auto
I bet it's your headlight switch. I've heard they go bad after awhile.
Vintageracer
Jan 10, 2020 05:33 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
apie2546
Aug 8, 2015 07:12 AM
