Sealing the wheel wells? What to use?
Old Aug 21, 2003 | 07:24 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I was out looking at the rear wheel wells a while back and noticed that some of the sealer that is put on from the factory is starting to crack in places and one place even had slight surface rust.
What I'm wanting to do is scrape off the loose sealer and recover the whole wheel well. I'm thinking that POR15 is the best stuff for the job as it's good with rust, but would I be better off using actual sealer like what is already painted on?
Hope I have described this properly.
Robert
Old Aug 21, 2003 | 07:47 PM
MechCD's Avatar
Car: '92 Camaro RS, '93 Ranger
Engine: LO3, Vulcan
Transmission: 700R4, M5OD
Axle/Gears: 2.73, 3.45
What I did was clean up the rust, throw some rust converter on, and then spray it from a can of undercoating. It seems to be holding up very well, and the ndercoating spray seems to melt or blend into the existing undercoating.
Old Aug 22, 2003 | 08:31 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
Hi Rob,
I just painted Hammerite black over the entire area twice, let it dry and then went over it all with Waxoyl. Looks really good and she's a rust dodger now. Otherwise I would use underseal.
Cheers,
Felix
Old Aug 22, 2003 | 10:31 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
POR-15 can't be beat for stopping rust.
Old Aug 22, 2003 | 02:48 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
We had some flat black rustoleum, the brush on kind in a can... I painted my wheel wells with it when I installed the pro-kit... looks good to me, has held up great... it's easy to get ahold of too, you could get it at any hardware store...
Old Aug 23, 2003 | 10:24 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
rustoleum
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
maroe624
Apr 16, 2017 08:29 AM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
Warlocksirix
Sep 3, 2015 12:26 PM
SPEEDY Z28
Wheels and Tires
Aug 24, 2015 06:26 PM
