help....rocker panel mounting rails
Old Sep 7, 2003 | 10:48 PM
bubbakutz's Avatar
Car: 1987 "1991 Z" Sport Coupe
Engine: LG4
Transmission: TH700R4
yes.....im having trouble.......in order to put on my side gfx i obviously need the mounting rails.....so my question is...does anyone know where i can get these? can i get them through chevy dealership? or has anyone made any....if so how did u do it.......i really need these things........help
Old Sep 7, 2003 | 11:29 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
You probably have about two options for them.
First one is to hit up a junkyard; bring a big hammer and cold chisel and remove a pair. I don't know if there is any difference between years and/or Camaro/Firebird rails. Try not to twist them too badly. Then when you get home, grind off the spotwelds smooth and affix them to your car.
Second option would be to fabricate some up from some pieces of sheet steel.
Pete
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
