Headliner glue?
Old Sep 9, 2003 | 07:11 PM
Tonyrodz's Avatar
Transmission: auto
Headliner glue?
Can anyone recommend a good headliner glue? I can't seem to find anything good. Whatever I find says not to use on a headliner!
Old Sep 9, 2003 | 07:36 PM
Dirty Rob's Avatar
3M spray adhesive works just fine.
Old Sep 9, 2003 | 07:38 PM
bubbareno's Avatar
Car: black on red 92 rs
Transmission: t-5
Use the 3m. Worked fine for me. Oh becareful of the corners if You have t-tops.
Old Sep 9, 2003 | 07:43 PM
bubbareno's Avatar
Transmission: t-5
Old Sep 9, 2003 | 07:44 PM
Tonyrodz's Avatar
Transmission: auto
I have the 3m stuff--but on the label it says not to use in high heat applications and not to use on headliners. Is there a different type of 3m spray adhesive that I'm missing or is that the stuff you guys used? If so how long has it held up for?
Old Sep 9, 2003 | 09:20 PM
demonchild's Avatar
about everyone on these boards have used 3m 90, works fine. if you search, there is some really good explanations on how to recover the headliner, some people are really proud on how theirs came out.
Old Sep 10, 2003 | 12:05 AM
87PontiacBeast's Avatar
Car: 92 firebird
Engine: 305 tbi
Transmission: t-5
ive seen in pepboys a spray adhesive actually meant for headliners.. never tried it but if its made for headliners it cant be too bad
Old Sep 11, 2003 | 07:01 AM
wilyk9's Avatar
Car: 85 Trans Am
Engine: 305 Carb
3M recommends #8088 (hope that # is right, going on memory) spray adhesive for lightweight headliners, and it withstands heat. I got mine at Advance Auto Parts, but other part stores carry it as well. That is what I used for mine and it worked great.
I would not recommend using 3M's general purpose adhesive as over time it may not hold due to the heat.
Old Sep 11, 2003 | 11:36 AM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
the gm spray w/ the green cap (i think) works well even tho it says not for headliners. the stuff w/ the purple cap is complete garbage, i think its 77? the green one is 90 i think. maybe i got those 2 backwards..
Old Sep 11, 2003 | 12:25 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
i used the permatex stuff and that stuff is STICKY!!!
i reccomend the 3M stuff or the permatex as well.
Old Sep 12, 2003 | 12:39 AM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
3M - General Trim Adhesive. In a white can with a black cap. Wal-Mart $8.50 or so.
Old Sep 12, 2003 | 12:39 PM
CaysE's Avatar
DO NOT USE #77 or #90!!! Your headliner WILL sag after a couple hot days.
I recommend anything that specifically is made for headliners. Personally, I would use 3M Fast Tack Trim Adhesive. If that's not available, use the 3M General Trim Adhesive; it just takes longer to set up.
Old Sep 12, 2003 | 01:45 PM
TekViper's Avatar
Engine: 3.1L v6
my black car has gone the entire summer with the 3m spray, i forget if its 77 or 90 but its the one w/ the green lettering on the can i think. the other kind sucks *** but the one i used was extremely sticky.
Old Sep 13, 2003 | 11:54 PM
CaysE's Avatar
I guarantee you'll be back here telling us that your headliner's sagging long before you hope it would.
Old Sep 14, 2003 | 11:28 AM
Tonyrodz's Avatar
Transmission: auto
I was able to grab the right stuff-I think it's by 3M--costs $12. Now hopefully I'll be able to do it before the cold damp weather comes back!
Old Sep 14, 2003 | 01:03 PM
mike graycar's Avatar
Car: 88 iroc x 2- 1 T-Top, 1 Vert
Engine: 350 tpi, 305 tpi
Transmission: 700R4-2800 stall, 700R4 stock
tony, it's mike here. you need to use 3m general trim adhesive #08088. i was doing the liner i bought from you. i allready flubbed it once. if your doing a t-top liner perhaps you should zip down and look at the one i'm doing. they are a pain in the nads. i will share with you the vast knowledge that only a super idiot like me can posess.
Old Sep 14, 2003 | 05:06 PM
Tonyrodz's Avatar
Transmission: auto
Mike w/the white Iroc?
Old Sep 14, 2003 | 06:03 PM
yes, that is I
Old Sep 14, 2003 | 09:59 PM
CaysE's Avatar
Guys, take it to PMs for stuff like that.
Where in NJ are you two? I can help out on the weekends if you need any. I've done one (hardtop) headliner already. The one in my car is about ready for some TLC, too.
Old Sep 15, 2003 | 01:18 AM
i'm in north west jersey. a little town called tranquillity. if you look on the rand-mcnally road atlas you may see it. if not do a search on the town side bar for "super idiot" i think i'm listed at g-8 on the map! i actually live about 10 minutes from island dragway (my second home). tony can be found streaking across new jersey at high rate of speed along rt. 80 on his way to work each day!-hope this helps !!
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 22, 2015 08:28 PM
MORREALE5
Sep 13, 2015 09:01 PM
blackbmagic
Sep 8, 2015 10:36 PM
