How do you replace the shifter ball on an 85 IROC?
Old Sep 18, 2003 | 10:03 PM
Adam Jones's Avatar
Just like the topic says...I need to know how to replace the shifter ball on my 85 IROC. I did a search but found little. I read some vague descriptions about a c-clip. Can anyone shed some more light on this for me?
Replies are always appreciated!
-AJ
Old Sep 18, 2003 | 10:31 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
To get to the c clip you need to take off the shifter button. It slides right up towards the roof. Keep an eye out for the clip that the button uses to keep itself held in place. After you have that outta the way then you will see the c clip down in the recessed area of the shifter ball.
Old Sep 20, 2003 | 08:03 PM
StreetRoc85 350's Avatar
Car: 88 IROC
Transmission: Pro 5.0 shifted T56
Axle/Gears: 10 bolt 3.73 posi
pull the shift button out of the shifter by just pulling up on it. then you should be able to look down onto the shift lever and the only thing that keeps that plastic ball on is a little c-clip just smaller than a dime. get 2 icepicks or 2 small screwdrivers and push on both ends of the C to pop it off. then the whole ball should just slide right up and off of it.
Old Sep 23, 2003 | 02:22 PM
kahamri's Avatar
Car: Camaro
Engine: More than one
Transmission: More than one
On a manual...do you have to cut it? It's a 92..i did the swap on the 90..but the 92 is a manual...
Old Sep 23, 2003 | 07:52 PM
Car: 88 IROC
no dont cut it, it just unscrews. get a rag or something for grip and just twist that sonvabitch 'till it comes off.
Old Sep 24, 2003 | 06:48 AM
kahamri's Avatar
Car: Camaro
man..why didnt i think of that...thanks g..it's comin off tonight..
NBrehm
Aug 25, 2015 11:49 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Fronzizzle
Aug 9, 2015 01:15 PM
Leggman1
Aug 6, 2015 04:15 AM
NBrehm
Aug 5, 2015 07:57 PM
