Front end clip????
Old Sep 23, 2003 | 11:40 PM
89RS-T's Avatar
Front end clip????
Buying a 83 camaro.. i dont like the 83 front clip i want the 91 front clip with the bow tie insert with the foglights.. The 83 already has ground affects. Can i get a 85 and up front end( i believe u can put the insert in the 85s and up) will it and the groud affects bolt on and line up if no how can i do this?? also what about clear corner blinkers for the 83 any one make them please help me with the front end i wanna get it in the paint shop and done thanks
Old Sep 24, 2003 | 03:19 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Yeah you can get an 85 and up front end clip. It will fit fine. The only thing that will cause problems are the ground effects. You will have to drill new holes for them to bolt in. Im not sure about the clear side markers.
Mike
Old Sep 24, 2003 | 04:54 PM
89RS-T's Avatar
ok what if i get a 85 front clip with ground effect will it line up to the originall ground effects on the fenders exe will it line up correctly??
Old Sep 24, 2003 | 06:47 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I've done an 84 Z28 cloned to a 92 Z28 before on my previous Camaro, 85-92 nose will work. The main thing I had to do is I had to cut 2 slashes in my 2 fenders for the 1992 Z28 front ground effect to attach it. You also might take this into consideration: When you put the 85-92 front nose on...you will have to cut away some of the plastic underneath for it not to bulge out. 82-84 Z28's had more plastic underneath. I cut away alot of it and the 85-92 nose bolted up fine.
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
bellez77
Sep 5, 2015 08:39 PM
